Slow clocks with pure sine wave inverter
terrynew
terrynew Solar Expert Posts: 48 ✭✭
All the digital clocks in my house, including in appliances, lose 1-2 minutes a day. This had been ever since I went off-grid nine months ago. I had thought it was just something to suffer through, but recently was told that it may be an inverter problem. The funny thing is that it's a full sine wave inverter (Magnum MA4448PAE), not a modified sine wave one that is known to cause digital clock troubles.
The specs say it outputs 60 HZ +/- 0.04%, which I figure shouldn't account for 1-2 minutes/day loss. Is there a way for me to confirm the frequency without buying an expensive scope or meter?
Any advice would be greatly appreciated. Thanks,
...Terry
    Re: Slow clocks with pure sine wave inverter
    That should be +/- 0.57 seconds per day error.
    Assuming your digital clocks use line frequency--that should be enough to "prove" that the inverter is not meeting specifications (by the way, I cannot find a model MA4448PAE inverter--is it is a "MS" model?).
    I wonder if the frequency can be "trimmed" to meet specifications (a small justifiable capacitor to tune the frequency)?
    Dave Angelini Solar Expert Posts: 6,753 ✭✭✭✭✭✭
    Measure with a frequency counter! A decent Fluke has one built-in. My favorite Agilent has that and an amazing ohms circuit for finding DC ground problems in noisy circuits. Kind of a 4 wire ohms meter that uses two wires and does a calulation to simulate what a 4 wire meter does. More than you need but nice to know that HP's offspring are definately still the cutting edge!
    Simple solution, use battery clocks!
  • waynefromnscanada
    I don't use 120 volt AC clocks for a couple of reasons, and suspect most others off grid don't either. First, I know inverters aren't dead on with their frequency, and second, electric clocks are viewed, at least by me, as parasitic loads. My solution? Battery operated digital clocks, then I know the time is right, especially as I have several and can compare :p
    Even on grid, I have a couple "atomic" battery clocks (and even a Casio wrist watch). So far, they work well for me and usually receive the radio signal ever day or two (the clocks/watch need to be kept away from electrical wires/interference to receive WWV after midnight).
  • terrynew
    Oops, you're right, Bill, it's an MS4448PAE.
    The battery-powered clock solution will work fine, but I'll have to train myself to ignore any appliance clocks.
    I'll see if I can borrow a Fluke or other meter with a frequency counter.
    Thanks,
    ...Terry
  • icarus
    A $15 kill a watt meter has a freq meter in it.
    I second battery clocks with rechargeable batteries in them. All we ever use.
    T
    I would be a bit surprised if the k-a-w was accurate to 0.04% --That is only 60Hz +/- 0.024 Hz.
    A digital/analog with second hand AC clock + accurate time source measured over a week+ is probably easier and more accurate (average over time) to see a +/- 0.57 second per day frequency error.
  • waynefromnscanada
    My k-a-w jumps back and forth between 60 Hz and 59 Hz, spending more time showing 60 than 59, so yes, it's close to 60 Hz.
    Like BB said: "A digital/analog with second hand AC clock + accurate time source measured over a week+ is probably easier and more accurate".
    A LOT more accurate! But really what's the point, we all know that inverters wonder around their design frequency. Now a $500,000.00 inverter, I'd expect to be a lot more accurate, but a battery operated clock costs much less. :p
    Argh... I've not thought about this. TV's and VCR's and such, wow, I will need a accurate source
    I've got one of those "atomic clocks"; receives radio signal from time base.
    Doesn't actually work at the cabin; radio signals have a hard time getting in there. :roll:
    Sometimes it doesn't get a signal elsewhere either.
    Any measuring device is only as accurate as whatever you compare it to; inevitably another measuring device. Or as Ogden Nash said: "A clock is something you check your watch against only to discover the clock is several minutes wrong." :p
  • machineman
    machineman Solar Expert Posts: 129 ✭✭✭
    The digital clock on my propane stove top has the same issue. Clock falls way behind but I haven't actually calculated the rate. It's always been off grid so I figured it was a proplem with the stove. I have Magnum MS-4024AE pure sine wave inverter running 21 months now without issue.
    Off Grid Cabin, 24V 440ah 6V GC battery bank, Xantrex MPPT60-150 CC, Magnum MS4024 inverter-charger, >1200w Solar bank
    I wonder if there is a "trim" cap on the 60Hz master, that can be fine tuned....
  • john p
    john p Solar Expert Posts: 814 ✭✭✭
    Buy a wrist watch. problem solved. or sync your computer..http://www.worldtimeserver.com
    this problem of clocks being inaccurate when run off inverters is not new and I have never found one inverter that has an accurate enough frequency keeping circuit. Its just not worth while for the manufacturer to go to the extra effort to use a trimmed crystal for frequency accuracy as most items opperate perfectly at + or - 5hz of 60 or 50 hz.
    I use pool.ntp.org for time sync on the computers.
    But the stove, microwave and VCR/DVD all have clocks, and same with clock radios . Well, I guess when I move to the ranch, I won't need the alarm clock, my PDA has that function, and cell network updates it's time. But I like all the clocks to read the same, and my watch keeps +- 20 seconds from DST to ST, so it's OK. But clocks loosing/gain minute a day, what a pain. And I'm sure they use the generic TV colorburst 3.xx MHz crystal as their timebase, what a shame if there is no way to trim it.
  • chevenstein
    chevenstein Solar Expert Posts: 100 ✭✭
    My Magnum inverter goes all over the place when it's not heavily loaded, according to my Kill-A-Watt. I've seen it as low as 45 Hz, but never much over 60. It seems to smooth right out when I apply any load over a few tens of watts. I don't have any clocks that plug into AC so this has only been something of a curiosity to me.
