Slow clocks with pure sine wave inverter
The specs say it outputs 60 HZ +/- 0.04%, which I figure shouldn't account for 1-2 minutes/day loss. Is there a way for me to confirm the frequency without buying an expensive scope or meter?
Any advice would be greatly appreciated. Thanks,
...Terry
Re: Slow clocks with pure sine wave inverter
That should be +/- 0.57 seconds per day error.
Assuming your digital clocks use line frequency--that should be enough to "prove" that the inverter is not meeting specifications (by the way, I cannot find a model MA4448PAE inverter--is it is a "MS" model?).
I wonder if the frequency can be "trimmed" to meet specifications (a small justifiable adjustable capacitor to tune the frequency)?
Measure with a frequency counter! A decent Fluke has one built-in. My favorite Agilent has that and an amazing ohms circuit for finding DC ground problems in noisy circuits. Kind of a 4 wire ohms meter that uses two wires and does a calulation to simulate what a 4 wire meter does. More than you need but nice to know that HP's offspring are definately still the cutting edge!
Simple solution, use battery clocks!"we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
I don't use 120 volt AC clocks for a couple of reasons, and suspect most others off grid don't either. First, I know inverters aren't dead on with their frequency, and second, electric clocks are viewed, at least by me, as parasitic loads. My solution? Battery operated digital clocks, then I know the time is right, especially as I have several and can compare
Even on grid, I have a couple "atomic" battery clocks (and even a Casio wrist watch). So far, they work well for me and usually receive the radio signal ever day or two (the clocks/watch need to be kept away from electrical wires/interference to receive WWV after midnight).
Oops, you're right, Bill, it's an MS4448PAE.
The battery-powered clock solution will work fine, but I'll have to train myself to ignore any appliance clocks.
I'll see if I can borrow a Fluke or other meter with a frequency counter.
Thanks,
...Terry -
A $15 kill a watt meter has a freq meter in it.
I second battery clocks with rechargeable batteries in them. All we ever use.
T -
I would be a bit surprised if the k-a-w was accurate to 0.04% --That is only 60Hz +/- 0.024 Hz.
A digital/analog with second hand AC clock + accurate time source measured over a week+ is probably easier and more accurate (average over time) to see a +/- 0.57 second per day frequency error.
My k-a-w jumps back and forth between 60 Hz and 59 Hz, spending more time showing 60 than 59, so yes, it's close to 60 Hz.
Like BB said: "A digital/analog with second hand AC clock + accurate time source measured over a week+ is probably easier and more accurate".
A LOT more accurate! But really what's the point, we all know that inverters wonder around their design frequency. Now a $500,000.00 inverter, I'd expect to be a lot more accurate, but a battery operated clock costs much less.
Argh... I've not thought about this. TV's and VCR's and such, wow, I will need a accurate sourcePowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I've got one of those "atomic clocks"; receives radio signal from time base.
Doesn't actually work at the cabin; radio signals have a hard time getting in there. :roll:
Sometimes it doesn't get a signal elsewhere either.
Any measuring device is only as accurate as whatever you compare it to; inevitably another measuring device. Or as Ogden Nash said: "A clock is something you check your watch against only to discover the clock is several minutes wrong."
The digital clock on my propane stove top has the same issue. Clock falls way behind but I haven't actually calculated the rate. It's always been off grid so I figured it was a proplem with the stove. I have Magnum MS-4024AE pure sine wave inverter running 21 months now without issue.Off Grid Cabin, 24V 440ah 6V GC battery bank, Xantrex MPPT60-150 CC, Magnum MS4024 inverter-charger, >1200w Solar bank
I wonder if there is a "trim" cap on the 60Hz master, that can be fine tuned....Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Buy a wrist watch. problem solved. or sync your computer..http://www.worldtimeserver.com
this problem of clocks being inaccurate when run off inverters is not new and I have never found one inverter that has an accurate enough frequency keeping circuit. Its just not worth while for the manufacturer to go to the extra effort to use a trimmed crystal for frequency accuracy as most items opperate perfectly at + or - 5hz of 60 or 50 hz. -
I use pool.ntp.org for time sync on the computers.
But the stove, microwave and VCR/DVD all have clocks, and same with clock radios . Well, I guess when I move to the ranch, I won't need the alarm clock, my PDA has that function, and cell network updates it's time. But I like all the clocks to read the same, and my watch keeps +- 20 seconds from DST to ST, so it's OK. But clocks loosing/gain minute a day, what a pain. And I'm sure they use the generic TV colorburst 3.xx MHz crystal as their timebase, what a shame if there is no way to trim it.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
My Magnum inverter goes all over the place when it's not heavily loaded, according to my Kill-A-Watt. I've seen it as low as 45 Hz, but never much over 60. It seems to smooth right out when I apply any load over a few tens of watts. I don't have any clocks that plug into AC so this has only been something of a curiosity to me. -
I've had the same experiences with several pure sine wave inverters. I noticed this when I first started with 12V, updated to a Edecor and a Vevor 24V, and now with a sungold 48V 6000W inverter/charger. Clocks lose about 2 minutes a day. It's not just the clocks in my situation as it also slows my water softener and solar hot water system. About once a month I have to set all about an hour ahead. I've tested with a kil-a-watt and it shows 59-60 but with a UNI-T and a Fluke it shows 50Hz. I suspect a kil-a-watt won't give an accurate reading from an inverter.I've just learned to deal with it as a difference from line power. My watch, computer clocks, and Accurite weather station have the correct times. Same as I've noticed my Milwaukee 7 1/4 saw has a slight improvement using grid power over inverter power.
Mr Jcwert, thx for reviving this thread. ...Kind of interesting to jump backward for a topic like this.Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
Same experience as the OP here. With the best of equipment. Xantrex 4048 for 11 years, Outback 3648 for 10 years...both cause stove clock to lose a couple of minutes in a week. No biggie...just look at other clocks (battery), watch or phone.
So if my old computer is running a bit slow I can adjust the governor on the genset a little to speed it up?
Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat. -
If you can measure the frequency change, you don't need a computer!
I’ve run into the same thing with a few different off-grid inverters over the years. The “59–60 Hz” you see on a Kill-A-Watt usually isn’t reliable on inverter output — those meters tend to smooth the waveform and miss the actual frequency drift. Your Fluke reading 50 Hz is much more believable, and that would definitely explain why clocks and timed systems lose minutes every day.
Most budget and mid-range inverters don’t hold frequency as tightly as grid power. They’re usually stable enough for motors and general loads, but anything with a quartz clock or timer gets thrown off pretty quickly. Some devices also use the AC frequency as a timing reference, so even a small deviation adds up over time.
One thing that helped in my setup was switching to an inverter with a better DSP control loop. Once I moved up to a higher-end unit, the frequency lock tightened up and my clocks stopped drifting. If you ever end up upgrading, something in the 12kW class with more stable frequency control might save you a lot of hassle — for reference, this is one example of the type I’m talking about: https://cmxbattery.com/product/12kw-18kpv-hybrid-inverter-charger-all-in-one-hybrid-inverter/
Not saying you need to replace anything right now, but you’re definitely not imagining the issue — it’s a pretty common quirk of budget inverter waveforms and their internal timing references.
- 231 Forum & Website
