? About 3 135 Watt Panels in Parralel
tcvb
tcvb Solar Expert Posts: 44
Will they need to be protected going to the charger?If so can i just tie them in a junction box?and put the protective device on the feeder going to charger?
Thank's
Tim
    Re: ? About 3 135 Watt Panels in Parralel
    In general, it is a good idea to place a series protection fuse in series with every (string--whether one or 10 panels per series string) when you have 3 or more parallel strings.
    The idea is that the series protection fuse will protect a shorted panel or lead wire from getting too much current from the rest of the panels on the string and cause a fire. Instead, the series protection fuse will open and prevent the over current into the failed string...
    One or two parallel strings do not need series protection fuses or circuit breakers.
    Many panel specifications will tell you what the series protection fuse rating is required.
    For example, a Kyocera 135 watt "12 volt" panel (PDF spec. sheet) with Isc=6.79 has a series protection fuse requirement of 15 amps maximum.
  • bobdog
    bobdog Solar Expert Posts: 192 ✭✭
    I am going to add the same panel to the 2 I have already (in parallel) and wondered how you actually put the fuse in line? Do you just use an automotive fuse type holder or what?
    Mine are paralleled at the pole then run the 30' to a 15 amp fuse/disconnect. But, that won't protect a bad module from the other 2.
    So, how does everyone put the fuse in line between each module (string)? Thanks.
    Tim
    Here are a few options from our host's web store.
  • Photowhit
    I think, it's primarilly a code issue.
    It was once common to combine them using a distribution block, NAWS still sells them here; http://store.solar-electric.com/16220-2.html
    IMHO glass, silicon and even tedar are not very likely to burn/burst into flames before some fine ribbon wire melts and disconnects the panel.
    That said, if it's on your roof and has collected debris and dried out... I wouldn't want to argue with your insurance company.
  • higgins
    higgins Solar Expert Posts: 56 ✭✭✭✭
    I'm in the UK,could i use RCD breakers in a domestic fuse box?These are circuits that will trip and stop residual currents leaking back,and they are slotted into a distribution fuse box with a switch for breaking all power to the circuits individually or all at once.
    Higgins
  • blackswan555
    blackswan555 Solar Expert Posts: 246 ✭✭
    Higgins
    You should use an RCD on the AC out to the house along with (M)CB`s (circuit breakers) same as you get in your house distribution panel, An RCD protect`s against earth leakage type faults, A (Miniature)CB against over current.
    For the DC side, you MUST use proper DC breakers or fuses, they are different internally and it can be extremely dangerous to use AC components in their place,
    Have a good one
    Tim
  • higgins
    Thanks Black swan,do you know where i can source the DC breakers and MCB'S in the UK?I have been looking at a few till it dawned on me that they they were AC types.Also trying to find uk equivalent hardware in place of American eqpt as most of them are on here thanks!
    Higgins
  • blackswan555
    Hope the Mod`s don`t mind, a very similar name that I have heard good things about but have never used my-self, http://www.windandsun.co.uk/
    Have a good one
    Tim
    Wow, I wonder who started business first? And infringements? At least there is a big pond inbetween
    quote from our us windsun site,
    "** 2010 is our 31th anniversary - 1979 to 2010. **"
    5 year discrepancy.
  • blackswan555
    I don`t use them directly, As I understand most of the OB European equipment now comes through them, Mine used to come (2nd) through Barden UK then onto Europe (Barden are also Rolls European distributors) but Barden (so I am told, try to buy OB through them) now do not deal "much" with OB and punt you on to windsun, politics I presume ?
    Tim
  • higgins
    Cheers Tim,good link that,
    Higgins
