Trying to understand how much Voltage is coming out of one Conext MPPT 80-600 Charge Controller
blacknbart
blacknbart Registered Users Posts: 20 ✭✭
Ok, I'm merely laying out my Off-Grid Plan and getting my Electrical plan figured out.  This system is on paper at the moment.  Without going into detail I have 320 VDC/ 20 Amps going into one MPPT 80-600 Charge Controller. How or what will the Charge controller output with that input?  I'm assuming this Charge Controller may have a Max output of 80 amps.  What will be my Volts in DC?
  • Aguarancher
    Aguarancher Solar Expert Posts: 315 ✭✭✭
    That all depends on your battery bank voltage and the state of charge for said battery bank.
  • blacknbart
    Aguarancher thx for the reply.   Looking to use the SimpliPhi Power’s PHI 3.8TM Battery (PHI-3.8-48-60) DC Voltage Range 48-56 VDC not sure if I'll be using 6-8 Batteries.  Will the Charge Controller output 48vdc, 80 amps?  A Preliminary Current Layout is Attached.
  • mcgivor
    edited October 2020 #4
    On the Simpliphi website there are instructions on how to set up the controller, this will involve setting the required voltage, bulk, absorption float, Ah capacity of the battery and so forth. There are different settings depending on warranty required  which have recently changed so use the current revision. The settings can then be copied to the inverter via Xanbus for generator or grid charging, check to verify the values are correct prior to commissioning the system.
    You will need an interface to adjust the settings,  a system control panel  (SCP),  ComBox, programming tool or the Web based Insight.
    DO NOT power anything up before verification of all settings as the default values are not suitable, they need to be customized.
    The way a MPPT controller works, is watts in = watts out  (minus a couple % consumed as heat and to power the electronics)
    at 55V charging the battery - you could expect 116 amps, but the controller has a 80A limiter, so you should do OK on cloudy days since you are somewhat overpaneled.
    And be sure you program the controller to match your battery before you do any serious charging
  • Photowhit
    You will generally want to use the VMP and IMP numbers they represent the numbers in a working system, If the are 40 volts and 10 amps, that would represent a 400 watt panel... VOC is important as the highest voltage the charge controller will see...
  • mcgivor
    @blacknbart
    With 32 × 310 panels the real world output would be 7440 W, that would amount to ~143 A at the typical charging voltage in the constant current or bulk stage where 99% of the charging of LiFePo4 occurs, there is no absorption to speak of.
    Then use of two controllers as it will exploit the maximum potential especially on a partly cloudy day when there are only a few hours of clear sky. LiFePo4 batteries  can accept much higher amounts of current compared to lead acid, which makes them suitable for offgrid because the only thing predictable with weather is its unpredictability.
    The charging voltage output of the controller will be regulated by the battery, typically the bulk target setting would be ~ 3.45 volts per cell  (VPC ) since the Simpliphi will have 16 cells in series the bulk voltage setting would be 55.2 V, when that is met there will be a short absorption of 6 minutes, this is the constant voltage stage, then it would transition to float at 54 V or 3.375 VPC.
    Please note that the values used above were taken from Simpliphi when I used their recommendations as a guide for my DIY LFP bank, their settings are dependent on warranty requirements and are constantly changing, I've attached the file but it may not be the latest revision.
    Don't sweat the settings, it's far easier than lead acid, the wiring diagram looks good and appears to be a well thought out ballanced system  in terms of design, loads independent.
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,110 ✭✭✭✭✭✭
    I would use the mppt-100-600v. It is in the store here or can be ordered. I am also a dealer for Schneider Solar and add my 30+ years of Offgrid installation advice for DIY.
    E-mail offgridsolar@sti.net
  • blacknbart
    Thanks, everyone for the calculations and insight on my plan.  We were originally thinking 28 panels, but I wanted to push it up to 32 just to see what the limit was.  We have a perfect South facing solar window and I foresee us gathering a high percentage of sunlight regardless of weather.  I also wanted to see if we went with a small array if we could add on if need be, maybe enough to charge a vehicle let's say. I'm not sure of the amount I'll need, but wanted to consider that since we are in California.  It wouldn't hurt, to say the least. @Dave Angelini, I'll look into the 100-600 MPPT if it makes all the difference.  Is that Charge Controller made for when you use 18 or more 48v batteries?
    This is in Dave's ballpark, look into hiring him to design your system properly.  Think of EVERYTHING you want to do, retrofitting to add features is expensive after something is designed.
