Power wall
Plucka
Registered Users Posts: 130 ✭✭
My understanding is they aren't sold by themselves only installed.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
That's my understanding as well, basic system Power Wall 2, 7Kw is $5900, + $700 for supporting hardware, + $800-$2000 installation charge, not including any electrical modifications, taxes or permit costs. Not mentioned is service costs, I'm sure to stay within warranty, any service would have to be peformed by a registered dealer.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
The Powerwall 2 is 13.5 KWH usable storage here in North America but mcgivors data is good about installation.
It is listed for grid only and they claim an offgrid model is in the works. They have had that claim for 3 years now.
One of my wrench buddies is a dealer and we have brainstormed how to use one offgrid sans warranty.
The model 2 really is a deal at that price except for the offgrid warranty part. Most LFP batteries are twice that cost."we go where power lines don't" Sierra Nevada mountain area
Powerwall can recharge from your solar power system and has the potential to run your home indefinitely? From Home Depot web site on the sales of powerwall. What's the story here it will work during an outage but how long?24 solar world 285 watt panels with 24 Enphase 250 s ground mount grid tied .
How long? As long as you use less than available solar + battery capacity + system losses?Off-grid.
Yes how long? You can always give Elon more money up front and get 2 or more...."we go where power lines don't" Sierra Nevada mountain area
Estragon said:How long? As long as you use less than available solar + battery capacity + system losses?
24 solar world 285 watt panels with 24 Enphase 250 s ground mount grid tied . -
southfork said:Powerwall can recharge from your solar power system and has the potential to run your home indefinitely? From Home Depot web site on the sales of powerwall. What's the story here it will work during an outage but how long?
You can't run your home indefinitely. There's no 'hooks' to allow AC coupling, and there's no option to do DC connection (i.e. direct connect to solar.) So once the grid goes out you can't use solar.
You can run an average efficient home (~12kwhr/day) for about a day before the battery dies. -
southfork said:Home Depot's sales person said about 7 plus days ? the cost is high but it would be nice to have power too pump water during a fire. I have a generator but fuel could be a problem in a disaster. They also claimed the powerwall would work with my Enphase grid tied system ? But in order to get more info I will need to sign up for a sales call.
mike95490 said:southfork said:Home Depot's sales person said about 7 plus days ? the cost is high but it would be nice to have power too pump water during a fire. I have a generator but fuel could be a problem in a disaster. They also claimed the powerwall would work with my Enphase grid tied system ? But in order to get more info I will need to sign up for a sales call.
If TESLA is able to do that, it is a game changer!,..... The Power Wall mainly carriers the house through the night They seem to be figuring in an average arrays output and the Power wall and batt bank work in tandem...??
Leaving the coupling with Enphase thing aside for the time being, how long you can go in a grid outage comes down to arithmetic. Solar can charge the powerwall and supply loads at a rate of X watts for Y time, depending on array size, weather, etc. At night, the array supplies zero watts.
If your power needs are low enough, the solar array is big enough, and the powerwall has enough capacity, you could go indefinitely without grid power. Some of us live off-grid, and do exactly that.
A good starting point would be to figure out what electrical loads you would really need/want to run in a disaster, and for how long. For someone to claim a system will last for 7 days or more without doing the arithmetic is like me saying my piece of string is long enough.Off-grid.
Ok I watched the whole video and I think I heard that it won't work if the grid is down ? But maybe the U.S. version is different ?24 solar world 285 watt panels with 24 Enphase 250 s ground mount grid tied .
It will not charge yet but it will work until empty. ! unless you open it up! Elon won't like that and no warranty."we go where power lines don't" Sierra Nevada mountain area
southfork said:mike95490 said:southfork said:Home Depot's sales person said about 7 plus days ? the cost is high but it would be nice to have power too pump water during a fire. I have a generator but fuel could be a problem in a disaster. They also claimed the powerwall would work with my Enphase grid tied system ? But in order to get more info I will need to sign up for a sales call.
The Powerwall contains a bidirectional inverter and a big battery. So let's say you buy one to complement your existing solar power system. You find a very good deal and sign up for it. Powerwall is installed and commissioned, and you get a sexy app on your phone that shows power flows. It shows the power flows from battery, solar and grid, and they change dynamically. You can even charge during the day from solar and discharge at night! Great!
Then the power goes out for a day and your house goes dark. The battery is still charged - you _know_ it's charged, and the light is on, but there's no power.
You call the installer guy.
"Yeah, well, you got the special deal. To give you real backup power we'd need to install a subpanel and move all your critical loads to that. That's a lot of work. We can do that but it's going to be another thousand."
"I don't want just critical loads - I want to power my whole home, like it says in the ads!"
"OK, well, we can move all the loads except the solar to the subpanel. But that's going to be more than a thousand."
So you pay the $$$ to move all the loads to the subpanel.
Then the power goes out again. This time, you have power for your home! But the display shows the solar generating nothing, even though the sun is out. You call the installer back again.
"Yeah, well, see, the solar is tied to the grid on the main panel; that's how we have to do it. So you can't charge from solar when the power is out. Power has to be on for that to work."
"But the ad said that . . . ."
"You might want to give Solar Experts Inc a call. I think they have a way to do that, but it's not normal."
So you call them. They tell you that there is a way, using AC coupling - provided your inverter and the Powerwall are compatible. To do that they are going to have to install yet more gear, specifically a big relay that will disconnect the solar power when the battery is close to fully charged, along with some specialized control gear. So you pay even more $$$ for that.
Then you have another blackout and the system works - and it charges from solar.
So all of that is doable. But I've seen three Powerwall installations so far, and none of them were AC coupled, and only one of them had a subpanel for backup loads. Make sure you know what you are getting. (And it's pretty much a guarantee that if you get a "great deal" on a Powerwall it's not going to include all that other stuff.) -
I'm just going to buy a drum of gas and some stabilizer and wait and see what they come up with next .
so is the power wall set up for off grid now ?2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
Yeah I know, YouTube videos are for the most part bogus, but this one is very informative about using the Powerwall in off-grid mode, there are 3 parts which describe in detail the problems encountered, this doesn't go into the contractual agreement on install, but focuses on what happens when the grid is absent for an extended period of time.
https://youtu.be/L9vtIFuarDo
I think that U-tube is one of the absolute best things out there. If you sign in with an account it is pretty hard to not just really like all the features. Without an account it is a wasteland.
When I responded to this previously we took the powerwall2 apart and just used the battery with an XW and some mppts. It works great but no warranty. It is still working just fine and easily stores 13kwh.
I never found his video #3, did you Ivor?"we go where power lines don't" Sierra Nevada mountain area
THX ! Number 3 was very useful for someone who really needed this system with all of it's quirks to work more than a day. Tesla has had on their battery web page for over 3 years now that they intend to release an offgrid model."we go where power lines don't" Sierra Nevada mountain area
Missed some of the video I was running around looking for what I thought was a bird chirping in my van
But it wasn't a bird?REC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array / MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware / OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system / Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2017 / System, Pics and Discussion
Yes it was a bird but on his video.Sounded like it was in my van
ok....what about NEC....those switches didnt look NEC approved
wheres the emergency shutoff....new rules that say each panel has to be disconnected individually ....does it also disconnect the high voltage battery from the system
arent lithium batteries explosive in a fire.....did he just put a bomb in his basement ( the fully charged guy)
elon musk runs his company like apple
steve jobs wanted end to end control of the hardware and software...same for elon musk.....he doesnt want you to know what is in it....and wants you to pay for anything other than basic functionality and doesnt want you to be able to fix it when it breaks
I understand wanting to make a profitable company.....but he goes too far
the xw system when I first got it...I didnt get the system control panel...its listed as an accessory
however, if you diont have it, you cant set any of the functions up and are at the mercy of basic functions....it will still work and if you had it installed, the installer probably used a config tool to set each function so no need for the SCP
extra $200 for the SCP...yup...not quite like apple or tesla....but you still had to buy extra to get more functionalityand still schneider ( formerly xantrex)....(xantrex formerly trace) wont release info on the proprietary xanbus so other people could maybe make their own controllers if they wanted to...but at least they dont charge you a small fortune for the extras they make, like tesla and apple does -
Tesla Powerwall is nominal 48vdc BTW.
Schneider does release modbus maps to control all of their devices, to anyone. All you need is a PLC device and you can do just about anything with an XW system.The xanbus is proprietary and they want to keep that safe (from unskilled) and get you to use their equipment.as you said.
So, did you get that XW to be reliable after your winter issues?"we go where power lines don't" Sierra Nevada mountain area
Dave Angelini said:Tesla Powerwall is nominal 48vdc BTW.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
