Nothing like honesty, Flexmax MPPT charge controller
mcgivormcgivor Posts: 1,746Registered Users ✭✭✭✭
  1500W, 6× Schutten 250W Poly panels , Schneider 150 60 CC, Schneider SW 2524 inverter, 8×T105 GC 24V nominal
  • littleharbor2littleharbor2 Posts: 914Solar Expert ✭✭✭✭
    Amazing isn't it? They also "copy" Victron charge controllers and probably many other products. I'd be interested in seeing a head to head comparison of this FM 80 and the real thing, performance and quality.
    2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old  but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
  • DConlyGuyDConlyGuy Posts: 80Registered Users ✭✭
    edited January 2017 #3
    i have their 100/30 mppt controller and it is very nice unit for 58 bucks compared to the over 200$ victron one
    https://www.aliexpress.com/store/product/30A-12V-24V-MPPT-Solar-charge-controller-with-CE-ROHS-SGS-real-MPPT-function/535617_32563125020.html  this the one i bought  they also copy the xantrax pure sine wave inverters . now what is funny is when i use the ve direct cable the victron software says i have a victron blue controller and even has a serial number too
    600 watts of solar panels,Epever 30 mppt , 2 PWHR12500W4FR battery's in 24 volt setup
    Even the 2" lcd is visibly exactly like the real thing. I have the Victron version. You would think the OEM's would blow a gasket seeing their products copied like this.
  • mike95490mike95490 Posts: 7,642Solar Expert ✭✭✭✭
    Vinnie - is the plant running a 3rd shift this month ?
