Need help choosing a generator
Re: Need help choosing a generatorAdjusting the AVR is slightly trickier as you are working around spinning parts. I just had my wife read off the voltage values as I made the adjustments.
Just a note on that - I would recommend against adjusting the AVR with the generator running. There is hazardous voltage at the brushes that will effectively end your journey on this earth if you accidentally touch one. Just take the AVR off with the two screws, tweak the little adjustment screw a tiny amount (clockwise increases voltage, counterclockwise decreases voltage), put it back on, start the generator and see what you get. It's a lot safer than handling an ungrounded AVR that has high DC voltages flowing thru it.
Chris -
Re: Need help choosing a generatorChrisOlson wrote: »Just a note on that - I would recommend against adjusting the AVR with the generator running. There is hazardous voltage at the brushes that will effectively end your journey on this earth if you accidentally touch one. Just take the AVR off with the two screws, tweak the little adjustment screw a tiny amount (clockwise increases voltage, counterclockwise decreases voltage), put it back on, start the generator and see what you get. It's a lot safer than handling an ungrounded AVR that has high DC voltages flowing thru it.
Chris
Whoops, will keep that in mind for any future adjustments. Thanks Chris. -
So, Champion it is.
I'll run it once a month or so for maintenance, but also to make sure it works.It regularly goes on sale at CT for $200 off.
That would be nice. How often does it go on sale?
I need to buy it before I switch off-grid, which I plan to do as soon as the snow clears from the ground. Hopefully they put it on sale soon -
Can't give you a number but if it I notice it on sale I will PM you. -
Re: Need help choosing a generatorI intend to keep the generater in the (heated) garage, away from the elements, then when time comes, pull it out, plug it into a receptacle in the wall (need to install that), start it and let it run.
Please give details of this receptacle.... I'm a bit worried that you are going to be using a 'suicide cord'. --vtMaps4 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i -
Re: Need help choosing a generatorPlease give details of this receptacle.... I'm a bit worried that you are going to be using a 'suicide cord'.
I'm going to use this receptacle. -
Re: Need help choosing a generator.....
I think it's a good idea to weld a cap or silencer on the exhaust......
Nope, too much back pressure. You could built a "tunnel" out of some 10" metal duct, and line it with fiberglass and metal hardware cloth, making a "glass pack muffler" to aim the exhaust into, but extending the pipe will ruin the engine.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
what's wrong with a flex pipe extension? Its no more than a long tail pipe and should not create a lot of back pressure.
Re: Need help choosing a generatorwestbranch wrote: »what's wrong with a flex pipe extension? Its no more than a long tail pipe and should not create a lot of back pressure.
Depending on the length, diameter and frequency of the sound waves from the engine's exhaust, a simple pipe can sometime increase exhaust pressure, decrease it, or make it louder. It's like the "stinger" on a two-stroke expansion chamber. They are precisely tuned to use the sound waves to create a vacuum on the engine's exhaust ports and improve cylinder scavenging and volumetric efficiency.
So I would advise caution when welding any old pipe on an engine's exhaust system.
Ideally, to limit the amount engineering you have to put into it, if you use a large diameter pipe and some sort of baffle (like the duct cap I used, showed in the photos of my gen enclosure project) you will not cause any adverse effects on the engine, and will make it quieter due to the baffle diffusing the sound waves. A muffler baffle can built many different ways - with fiberglass packing like somebody else mentioned - or a simple tube with many holes drilled in it does the trick. The vent cap I used has chisel cut holes in it and it works excellent.
But just an open pipe extension can cause anything from a sharp "rap" (vacuum on the exhaust due to sound wave expansion when it hits the atmosphere) to more a "hissing" type sound (excessive exhaust pressure) from the sound waves "piling up" when they hit the atmosphere.
Chris -
Visited Canadian Tire. Just about any generator is on sale, except the Champion.
Bough receptacle, wires, etc. Will wire everything up and wait until it goes on sale. -
Re: Need help choosing a generatorVisited Canadian Tire. Just about any generator is on sale, except the Champion.
Typical that whatever you want isn't on sale.
CT has good customer service though; they will sometimes look back a month and see if it was on sale and give it to you for that price, and they'll always give you a refund if it goes on sale within 30 days of your purchase. Not many stores will do that for you. -
Actually they can look forward and tell you when the next sale will be too, but not the price of it , I guess TBD.
Is the sale price better than what you can get it for on Amazon? Although I suppose if you order on Amazon you have to pay the 15% tax to get it across the border. Not sure on that, but probably.
Chris -
Re: Need help choosing a generatorChrisOlson wrote: »Is the sale price better than what you can get it for on Amazon? Although I suppose if you order on Amazon you have to pay the 15% tax to get it across the border. Not sure on that, but probably.
Chris
Plus duty, shipping, hassles, delays, and worst of all ... no Canadian Tire money! -
Thanks guys! I didn't know Canadian Tire was that good. I'll ask them.
Amazon doesn't ship most of the things to Canada. There's Amazon.ca, but it has very few products and they're usually very expensive. -
Re: Need help choosing a generatorThanks guys! I didn't know Canadian Tire was that good. I'll ask them.
Has more to do with the individual company than Amazon. If the company that is registered with Amazon ships to Canada, then it will be on Amazon.ca. I noticed that there is more listed on there than there used to be.
I'm not impressed with CT's return policy. They can be really sticky about returns, whereas, other retailers will take a product back no questions asked, in some, if not many cases. Also, I know a fellow that sued a particular CT store over a defective product, as they wouldn't give him his money back. He sued the store and won the case. This had more to do with a particular CT store though, which was mismanaged. The store is now being run by a new owner. -
Re: Need help choosing a generatornortherner wrote: »Has more to do with the individual company than Amazon. If the company that is registered with Amazon ships to Canada, then it will be on Amazon.ca. I noticed that there is more listed on there than there used to be.
There's room for huge improvement yet. Especially in the pricing department. :grrI'm not impressed with CT's return policy. They can be really sticky about returns, whereas, other retailers will take a product back no questions asked, in some, if not many cases. Also, I know a fellow that sued a particular CT store over a defective product, as they wouldn't give him his money back. He sued the store and won the case. This had more to do with a particular CT store though, which was mismanaged. The store is now being run by a new owner.
You must have a lousy local store. I've never had any trouble at all with CT and returns in four different locations in BC. -
I've never had a problem with the retail side of the Canadian Tires that I've dealt with - they've always been good with returns and telling me when the next sale is. However, don't get me started on their car repair side of the house... -
Re: Need help choosing a generatorCariboocoot wrote: »You must have a lousy local store. I've never had any trouble at all with CT and returns in four different locations in BC.
Yes, I heard that the Peace River store was poorly managed. It is under new ownership now, however. -
The Champion 5500 is on sale starting tomorrow for $599.99 -
You just beat me to it Marc -
Re: Need help choosing a generatorCariboocoot wrote: »The Champion 5500 is on sale starting tomorrow for $599.99You just beat me to it Marc
Thank you!!! Will try to buy it. -
Here are the links to adjusting the frequency, voltage and other tech bulletins:
http://www.championpowerequipment.com/pdf/tech-bulletins/rpm_and_frequency_adjustment-8_10_2007.pdf
http://www.championpowerequipment.com/pdf/tech-bulletins/avr_voltage_adjustment-1_4_2007.pdf
http://www.championpowerequipment.com/tech-bulletins/
Anyone know why they would suggest setting the voltage to 250V instead of 240V? Are they assuming a big voltage drop through typical extension cords? The meter on my XWSCP measured the frequency at 65Hz and the voltage on L1 and L2 at ~132V before I made my adjustments. -
Re: Need help choosing a generatorAnyone know why they would suggest setting the voltage to 250V instead of 240V? Are they assuming a big voltage drop through typical extension cords? The meter on my XWSCP measured the frequency at 65Hz and the voltage on L1 and L2 at ~132V before I made my adjustments.
They have some governor droop because of the mechanical governor. Champion likes to see the voltage and freq set over nominal at no-load so that when the generator is loaded to 50% load it is dead on nominal and stays within reasonable sag limits at full load. The assumption, of course, is that the generator is not operated at no-load except for startup and cooldown.
Chris -
Makes sense. I made my adjusts at 70% load (~240V) and checked it again at 5% (~245V).
NorthGuy, if you are "lucky" the sale the price will be $640..........benefit of living in the north. -
Re: Need help choosing a generatorHere are the links to adjusting the frequency, voltage and other tech bulletins.
Thank you. I hope it'll be adjusted when I buy it, but I'll check.
Followed you link and found instructions for unbonding neutral from the frame. Will have to do that too. -
Let it break in, a few days of good hard work if you can, then get out the K-a-W and set it up with a moderate load using the K-a-W for the cycles, Volts should follow.
hth
Re: Need help choosing a generatorwestbranch wrote: »Let it break in, a few days of good hard work if you can
You mean few days with few hours per day?
I was going to run it for 3-4 hours under load charging batteries as soon as I get a cloudy enough period, and I thought that would be enough. -
What is the purpose of unbonding the neutral? Would you just unbolt it from the frame and then tape it up or is there more to it than that? -
Re: Need help choosing a generatorWhat is the purpose of unbonding the neutral?
To prevent current from flowing through the ground wire, which can happen if you have more than one neutral, ground bond in the system.
- 628 Discussion Forums/Café
