confused about solar water pumping for domestic use
tomN
Registered Users Posts: 7 ✭
i am thinking about putting in a solar water pump system for my residential and garden use. i have a 2" well 30' deep and the water table is aproximately at 20'. i am thinking of putting in a shurflo 5.7 gpm pump whisper king 10 amp @65psi, a35g pressure tank 1 123 watt solar panel and 12 deep cycle battery. the verticle run would be no more than 200' is this overkill or do i need a larger panel
Re: confused about solar water pumping for domestic use
65 PSI will lift the water about !~ 130 vertical feet TOTAL with MAYBE 1 psi of delivery pressure.
So if you have to go 200 feet vertical you need a bigger pump...
Eric
sorry about that i meant 200' horizontal -
If your water is 20 foot down, very unlikely that most pumps can suck it up that high from the well. -
that would mean that i would have to use a motorized pitcher pump then? -
or a submersible, in the borehole, pump.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: confused about solar water pumping for domestic usei have a 2" well 30' deep
I am not sure where you got the 65 PSI and 10 amp but the spec sheet
http://www.shurflo.com/files/RV-Product-Data-Sheets/Classic-Series-Pumps/Whisper%20King%20Pump%20-%20pds-2093-204-113.pdf
only shows 30 psi and a priming lift of 9 feet. meanig it can only suck water UP 9 feet.
Eric
ps never heard of a 2 inch bore hole for a well.. most are 6 inch for domestic and the submersible pump used would be about 4 inch in diameter.
ej
downhere in the sunny south it is very common to have a 2" well for residential use and normally you don't have to go to far to get water. i live about 18 miles from the coast and this is the pump that i was thinking of extreme series smart pump5.7 from shurflo product # 5900-0201 -
2" or 2.25" well casings are pretty common for windmills. They are also usually pretty old, since many states have required at least a 6" bore for several decades for new wells unless specifically for a windmill. Nearly all new wells around here - even for windmills - use a 6" bore and drop a 2.25" casing in it for windmills. -
Re: confused about solar water pumping for domestic useat least a 6" bore for several decades for new wells unless specifically for a windmill
Tom, it doesn't look like that one is self priming, ie it has to have its supply at the same level as the pump, like in an RV.
eric
I also have a two-inch well casing and the only suitable pumps I have found for it are reciprocating windmill types. Air lift is another option.
There are some environmental sampling pumps that would fit, but I've spoken to some people about them and they don't think they would cut it for domestic duty. -
Try the environmental sampling pump, pump into a holding tank (large) and then pump with a booster pump. the Environmental pumps are cheap, so give it a try.
Tony -
2" wells are very common here in the South, especially around this part of Texas. A shallow well jet pump (at sea level) should be able to suck water from 25'.
This is what I have been looking at :
http://sunpumps.com/ProductsClient.aspx?ProductChildNodeId=241&ProductChildNodeText=Centrifugal%20Surface%20Pumps&SeriesID=119
I might have an answer for you soon. I would also like to investigate using a std. pump/motor with an inverter, but I think the inverter will push the cost out of reach. -
Re: confused about solar water pumping for domestic usedownhere in the sunny south it is very common to have a 2" well for residential use and normally you don't have to go to far to get water. i live about 18 miles from the coast and this is the pump that i was thinking of extreme series smart pump5.7 from shurflo product # 5900-0201
But you said water table was 20' down from ground level.
It is the water table level that counts, not the depth of the well collector tip.
You might get by with a well side priming injection and a check valve at the top. The prime water amount depends on how fast the water disperses at well point.
I remember my father had a well with about a 18' water table. He rigged an old insect sprayer (like a thin bicycle pump) to pull enough vacuum to bring water up to pump. Had to prime it if it was not used for greater then several months.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
