Direct Grid Technologies Microinverter
It looks like enphase has some competition. The dc input voltage is higher than the enphase model. Is anyone going to be trying these things when they come out? website: www.directgrid.com.
  • Solar Guppy
    Re: Direct Grid Technologies Microinverter
    CEC weighted efficiency of 92% and maximum input current of 2.35 amps
    http://www.directgrid.com/index_files/PDFs/dgasmart.pdf
  • GreenerPower
    GreenerPower Solar Expert Posts: 264 ✭✭✭✭✭✭
    Hmm! 20-year guarantee, 120VAC grid-tie. The power co is going to be busy tracking down guerilla installs.
    They use the same capacitor brand as the Enphase.
    GP
  • Toner Duckpin
    Toner Duckpin Registered Users Posts: 7
    I found this interview on youtube.
    http://www.youtube.com/watch?v=RSoXUx1jfoA
  • halfcrazy
    halfcrazy Solar Expert Posts: 720 ✭✭✭
    they really limited there options when they gave that high of an input voltage and that low of an input current
    halfcrazy wrote: »
    Wow with these specs;
    Rated input voltage range 150V –188V
    Max. DC input voltage 190V
    Nom. DC input current 1.23A 1.75A
    Max. DC input current 1.6A 2.35A
    They have a pretty small target group!
    For What It's Worth - Enphase was NOT the first doing a mcrosine inverter, I doubt even Trace's Micro sine was the first,
    Here's a Legacy PDF from Kyocera that show the panels mounted Trace Microsine inverter (2/3rrds down on right);
    http://kyocerasolar.com/pdf/specsheets/linetie.pdf
    Here's a PDF of a 1998 HomePower "guerrilla solar" article, this was a regular feature article of HomePower in the earlier years when POC and authorities didn't know what to do with us solar wingnuts!
    http://www.pha.jhu.edu/~tunison/renew/docs/guerrilla.pdf
    The article actually states "These inverters had been around for a while before Trace picked up the US rights. They are not Trace-designed inverters"
    This also shows the Micro sine inverter just plugged into an outlet with a male plug, though I don't know if that was Traces intent, These did have UL listing!!!
