Direct Grid Technologies Microinverter
Toner Duckpin
Registered Users Posts: 7 ✭
It looks like enphase has some competition. The dc input voltage is higher than the enphase model. Is anyone going to be trying these things when they come out? website: www.directgrid.com.
Re: Direct Grid Technologies Microinverter
CEC weighted efficiency of 92% and maximum input current of 2.35 amps
http://www.directgrid.com/index_files/PDFs/dgasmart.pdf -
Hmm! 20-year guarantee, 120VAC grid-tie. The power co is going to be busy tracking down guerilla installs.
They use the same capacitor brand as the Enphase.
GP -
I found this interview on youtube.
http://www.youtube.com/watch?v=RSoXUx1jfoA -
they really limited there options when they gave that high of an input voltage and that low of an input current -
Re: Direct Grid Technologies Microinverterthey really limited there options when they gave that high of an input voltage and that low of an input current
Wow with these specs;
Rated input voltage range 150V –188V
Max. DC input voltage 190V
Nom. DC input current 1.23A 1.75A
Max. DC input current 1.6A 2.35A
They have a pretty small target group!
For What It's Worth - Enphase was NOT the first doing a mcrosine inverter, I doubt even Trace's Micro sine was the first,
Here's a Legacy PDF from Kyocera that show the panels mounted Trace Microsine inverter (2/3rrds down on right);
http://kyocerasolar.com/pdf/specsheets/linetie.pdf
Here's a PDF of a 1998 HomePower "guerrilla solar" article, this was a regular feature article of HomePower in the earlier years when POC and authorities didn't know what to do with us solar wingnuts!
http://www.pha.jhu.edu/~tunison/renew/docs/guerrilla.pdf
The article actually states "These inverters had been around for a while before Trace picked up the US rights. They are not Trace-designed inverters"
This also shows the Micro sine inverter just plugged into an outlet with a male plug, though I don't know if that was Traces intent, These did have UL listing!!!Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
- 231 Forum & Website
