magnet generator
krisman
Solar Expert Posts: 57 ✭✭✭✭
i know this isnt a place for magnet discussions. but was wondering if you could make a generator based on magnets? ive heard of it before and was needing some help setting up a system
Re: magnet generator
Permanent magnet spinning past a coil of wire - one of the oldest designs there is!
Lots of DIY wind genny projects use permanent magnets - sometimes replacing rotor coils in alternators and sometimes converting DC motors.
Interested in DIY Wind power? You can't beat Otherpower http://www.otherpower.com/ for resources in that area! -
Wires. Magnets. Motion. it's all in wikipedia.
Also, some great instructions at
http://www.otherpower.com/guemes_notes.html
http://www.otherpower.com/otherpower_links.htmlPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Yep ! And sometimes they make generators from electro-magnets instead of
permanent magnets.
boB -
I'm thinking of the bicycle's dynamo, whether it gives you enough power for your need.
A PMA (Permanent magnet alternator) is just a "giant" version of the bicycle's dynamo.
GP -
Inverter-generators also use permanent magnets on the rotor. -
yes a permanent magnet system generator is what im looking for, ive tried googeing and everything with no luck, ive saw where you can get an ebook for the plans on making one but its 49 bucks. im looking for something like this, http://www.youtube.com/watch?v=V-MQvzOCNSI, [moderator note: This is a classic over unity / perpetual motion machine. Take with a grain of salt. -Bill B.] where it takes small wattage to run and disperses more wattage to power things. this is pretty much a windmill without the wind isnt it? -
That's a scam. This belongs to the "perpetual machine" class. Found plenty similar on the internet. Energy output needs energy input, can not generate from "nowhere".
GP -
Then again.... If you get a big coil, some ferrous material and an energy source to discharge into the coil, you can actually Generate your own Magnets !!
Now THAT's a REAL "Magnet Generator" !
boB -
this page talks about Stepper motors...
http://thebackshed.com/Windmill/articles/GettingStarted.asp
Ericc
