Electromagnet AC or DC?
Can any smarties decipher the info plate at all?
Auction ad said 240 volts. Owner said he never used it.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Probably 230 VDC from what I can find quickly... There are also 24 VDC coil versions too (light duty). A "small" 230 VDC takes 12 amps (or ~3kWatts)....
Example of data sheets:
https://www.genscoequip.com/admin/products/attachments/canmag_2025_brochure.pdf
Ok thanks! I don’t know of any realistic way to supply 3 kW of DC power unless I buy an AC to DC converter.Since the strength of an electromagnet is dependent upon the supplied current, I would be inclined to suspect that more current would make a stronger magnet. The positive wire has a diameter of .427 including the insulation. Guessing that is about 1awg wire based on hazy memories.I would think the wire diameter would indicate the desired supply of current. Running on DC throws a wrench in what I can easily do.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Finding a 220/240 VAC to 230 VDC converter is proving quite difficult. Not the first time I have tried.It does seem that a 5000 watt converter should be used to reliably run 3000 watts.Anybody know of an affordable option?First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Thinking a DC step up transformer should be doable. Run it off of batteries.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Unit is ~ 38” wide. Currently available and similar unit requires: 18 amps at 230 DC. 6 KW/6000 watts.Tall order for something I thought would be fun. Cost ~ $350. I did a small electromagnet for Show & Tell when 8-9 years old. Hence the interest.Could serial nineteen 12 volt batteries. Yikes. At least the higher voltage allows for smaller wires - I believe. But that 6000 watt figure may indicate otherwise?First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
19 batteries is not a good solution. Anybody know of a DC step up transformer that goes up to 230 volts?They all seem to be AC or DC to AC or, in the case of battery chargers, AC to DC.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Technically, all transformers are AC... There are no DC transformers. Need the "alternating current" to create the constantly changing magnetic fields to transfer energy in a Transformer.
https://www.explainthatstuff.com/transformers.html
There are hydraulic and diesel powered gensets. Also rectifiers for AC to DC conversion. None of this stuff looks cheap, unless you can find at auction/abandoned/etc.
Just an idea of rebuilt/used magnet prices:
https://www.genscoequip.com/used-scrap-demolition-equipmentREBUILT SCRAP HANDLING MAGNET
CANMAG Cast Steel Scrap Magnet
Model LMR170- 67" Diameter Cast Steel Shell
- 82 Cold amps at 230V DC
- Requires min. 20kW generator
- Weight: 7,800 lbs (aluminum coil)
- 8 mo. Warranty
- c/w new heavy chains, connectors
Price: $ 22,000 USD
NATIONAL COIL Cast Steel Scrap Magnet
Model Millmaster 68D- 68" Diameter Cast Steel Shell
- 73.3 Cold amps at 230V DC
- Weight: 10,350 lbs (copper coil)
- 6 mo. Warranty
Price: $ 28,000 USD
Rebuilt DTX4/610 Alligator Shear
HEAVY DUTY Hydraulic Alligator Shear for scrap metal c/w Hydraulic Scrap Hold Down arm.
Model DELTAX 4/610E (Foot pedal control)
Complete with 24-inch blades
10 HP 230/460/575-volt motor, 3 phase (Single phase optional)
Capacity Rounds: 2” mild steel rounds
Weighs approx 2,650 lbs
120-ton shearing force
Floor Space: approx 65&… Show MoreRebuilt Scotty Alligator Shear
Model SCOTTY #10
Complete with 10-inch blades
15 HP 230 volt motor, 3 phase
Weighs approx 3,000 lbs
Floor Space: approx 65” x 90”
Fully rebuilt Hyd. Cylinder hoses, Limit Switches and Controls repaired valve… Show MoreUSED MERCURY 120 BRIQUETTER
MERCURY 120 BRIQUETTING PRESS
A high-speed production baler for non-ferrous, cans and light steel applications. Features include continuous feeding with powerful shearing ram, side compression cylinder, and automatic cycling. Produces a 12” x 12” x variable length bale at a rate of up to 6-8 tons per hour – depending on the mate… Show MoreUSED CSX 2010 CABLE STRIPPER
Strip Heavy-Duty Cable from 1/16" - 4-1/2" diam
- Strip heavy-duty wire 1/16" x 4-1/2" diameter
- Stripping Speed:110'/min
- Fully adjustable blade and feed roller assembly
- Forward and reverse control
- Automatic safety braking system
- Separate stripping area for small wire
Overall Dimension: Approx. 30"x&n… Show More
Used Guidetti Wire Recycling System
GUIDETTI SINCRO MILL 415 WIRE PROCESSING SYSTEM
SINCRO MILL 415 Processing System (for a midsize-large processor, all types of wire and cable especially LOW GRADE) – 75HP motor power - Automated system with PMG600-E pre-shredding machine for simple operation and processing of cable and wire
MAX INPUT CABLE SIZE – PRE… Show MoreUsed Downstroke Balers
Used Downstroke Vertical Scrap Balers
Balers designed for light gauge and heavy scrap, Al. extrusion, aluminum cans/bottles, copper, OCC, paper, etc. These balers are built much heavier with tremendous downforce platen strength offering greater bale density
MAXPAK Model 6020-66-7 - 7" main cyl, 4.5" rod, 66" stroke, ram pressure = 90,… Show MoreUsed Skidsteer Scrap Grapple
Used (2024) Skid Steer Scrap Grapple c/w dual hydarulic arms, lower bucket with bolt on blade, 73" wide x 34" depth - 24" high. Comes with quick attach, hyd. hoses and fittings
Price: $5,600 USD + shippingScrap / Demolition / Recycling
- Balers and Briquetters
- Automatic Wire Stripping Machines
- Dust Control Systems & Accessories
- CABLE WIRE RECYCLING MACHINES & METAL PROCESSING SYSTEMS
- Scrap and Demolition Grapples
- Portable Cutting and Crushing Tools
- Magnet Generators and Accessories
- Scrap Magnets
- Mobile Shears & Demo Attachments
- Rotary Shear & Hammer Mill Shredders
- Portable Metal Scrap Baler/Logger
- Scrap Metal Alligator Shears
- Non-Ferrous Shredders
- Metal Chip Briquette Machinery
- CONTAINER LOADERS
- AUTO RECYCLING AND DEPOLLUTION EQUIPMENT
Rebar Benders and Rebar Cutting Tools
Electrical Power & Utility Tools
Lukas / Vetter Industrial
Dynaset Hydraulic Accessories
Excavator & Crane Attachments
Railway Maintenance Equipment
Used Scrap, Demolition & Rebar Equipment
SIGNUP TO OUR NEWSLETTERGensco Equipment Inc.
53 Carlaw Ave.
Toronto, Ontario, M4M 2R6
Canada
Telephone: 416-465-7521
Fax: 416-465-4489Cookie Policy
I usually hope that BB will do his best to solve an issue. Thanks!!!My unit needs 18 amps at 230VDC. Quoted data below indicates a need for an ~ 5000 watt generator. That isn’t a problem. But turning the AC into DC is currently a pretty big problem.
- "82 Cold amps at 230V DC
- Requires min. 20kW generator”
Their prices may be on the high end. Judging by this:"Used (2024) Skid Steer Scrap Grapple c/w dual hydarulic arms, lower bucket with bolt on blade, 73" wide x 34" depth - 24" high. Comes with quick attach, hyd. hoses and fittingsPrice: $5,600 USD + shipping”Still good to see that my magnet may have a value in the low thousands - with some additional parts. Made by Square D a long time ago. I would bet that it has copper windings - not aluminum.So I need a large rectifier. Sounds like a good start.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Then we have this:
"AC to DC Calculator
To convert ac voltage to dc voltage enter value in given field by using our ac to dc converter calculator.
Select Unit (AC / DC):AC DCEnter DC Current: 230AC Current 361.6352 volts"That is three phase voltage. A three phase generator is expensive. Then I also need the large rectifier as well. Sigh.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
You're already finding more info than i did. I did find a list of new smaller magnets:They have a 20" dia magnet that takes 900 watts at 90voltsDC so about 10amps?They say it weighs 530 pounds and can lift 10,500 pounds. Do you have anything that can lift that much weight high enough off the ground to be useful? Sounds dangerous. I've seen people tip small cranes over being careless.Think carefully about your DC-DC conversions. Assuming 100% efficiency, It would take 100amps @10 volts to create 10amps @ 100 volts. So huge current demands at lower voltages.Batteries could be dangerous. You won't know when they are too weak to keep holding your weight! Besides, batteries don't like uncontrolled high current discharges. Any weakness could produce a catastrophic failure. Then you'd have a falling weight and an exploding battery. Be careful!Sol-Ark 12, 3 Pytes V5 100ah batteries, currently six REC 420w panels installed. Ten more panels waiting to be installed.
Hah. Looking at downstroke balers brings back memories. We were just creating 700 lb bales of cardboard though. Getting rid of the empty boxes was the easy part.
Sol-Ark 12, 3 Pytes V5 100ah batteries, currently six REC 420w panels installed. Ten more panels waiting to be installed. -
This reminds me of that episode of Breaking Bad where they use that large magnet to destroy the laptop that's inside the evidence room.
Good point about weakened batteries losing their grip.manzanita2 said:You're already finding more info than i did. I did find a list of new smaller magnets:They have a 20" dia magnet that takes 900 watts at 90voltsDC so about 10amps?They say it weighs 530 pounds and can lift 10,500 pounds. Do you have anything that can lift that much weight high enough off the ground to be useful? Sounds dangerous. I've seen people tip small cranes over being careless.Think carefully about your DC-DC conversions. Assuming 100% efficiency, It would take 100amps @10 volts to create 10amps @ 100 volts. So huge current demands at lower voltages.Batteries could be dangerous. You won't know when they are too weak to keep holding your weight! Besides, batteries don't like uncontrolled high current discharges. Any weakness could produce a catastrophic failure. Then you'd have a falling weight and an exploding battery. Be careful!First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
