Electromagnet AC or DC?
softdown
softdown Solar Expert Posts: 4,024 ✭✭✭✭
Can't find any info anywhere.
Can any smarties decipher the info plate at all?
  • softdown
    Auction ad said 240 volts. Owner said he never used it.
    BB. Super Moderators, Administrators Posts: 33,706 admin
    edited September 6 #3
    Probably 230 VDC from what I can find quickly... There are also 24 VDC coil versions too (light duty). A "small" 230 VDC takes 12 amps (or ~3kWatts)....
    Example of data sheets:
    https://www.genscoequip.com/admin/products/attachments/canmag_2025_brochure.pdf
  • softdown
    Ok thanks! I don’t know of any realistic way to supply 3 kW of DC power unless I buy an AC to DC converter.
    Since the strength of an electromagnet is dependent upon the supplied current, I would be inclined to suspect that more current would make a stronger magnet. The positive wire has a diameter of .427 including the insulation. Guessing that is about 1awg wire based on hazy memories.
    I would think the wire diameter would indicate the desired supply of current. Running on DC throws a wrench in what I can easily do.
  • softdown
    Finding a 220/240 VAC to 230 VDC converter is proving quite difficult. Not the first time I have tried.
    It does seem that a 5000 watt converter should be used to reliably run 3000 watts.
    Anybody know of an affordable option?
  • softdown
    Thinking a DC step up transformer should be doable. Run it off of batteries.
  • softdown
    Unit is ~ 38” wide. Currently available and similar unit requires: 18 amps at 230 DC.  6 KW/6000 watts.
    Tall order for something I thought would be fun. Cost ~ $350. I did a small electromagnet for Show & Tell when 8-9 years old. Hence the interest.
    Could serial nineteen 12 volt batteries. Yikes. At least the higher voltage allows for smaller wires - I believe. But that 6000 watt figure may indicate otherwise?
  • softdown
    19 batteries is not a good solution. Anybody know of a DC step up transformer that goes up to 230 volts?
    They all seem to be AC or DC to AC or, in the case of battery chargers, AC to DC.
    Technically, all transformers are AC... There are no DC transformers. Need the "alternating current" to create the constantly changing magnetic fields to transfer energy in a Transformer.
    https://www.explainthatstuff.com/transformers.html
    There are hydraulic and diesel powered gensets. Also rectifiers for AC to DC conversion. None of this stuff looks cheap, unless you can find at auction/abandoned/etc.
    Just an idea of rebuilt/used magnet prices:
    https://www.genscoequip.com/used-scrap-demolition-equipment
    REBUILT SCRAP HANDLING MAGNET
    CANMAG Cast Steel Scrap Magnet
    Model LMR170
    • 67" Diameter Cast Steel Shell
    • 82 Cold amps at 230V DC
    • Requires min. 20kW generator
    • Weight: 7,800 lbs (aluminum coil)
    • 8 mo. Warranty
    • c/w new heavy chains, connectors
      Price: $ 22,000 USD
    NATIONAL COIL Cast Steel Scrap Magnet
    Model Millmaster 68D
    • 68" Diameter Cast Steel Shell
    • 73.3 Cold amps at 230V DC
    • Weight: 10,350 lbs (copper coil)
    • 6 mo. Warranty
      Price: $ 28,000 USD
    Show Less
      Rebuilt DTX4/610 Alligator Shear
      HEAVY DUTY Hydraulic Alligator Shear for scrap metal c/w Hydraulic Scrap Hold Down arm.
      Model DELTAX 4/610E (Foot pedal control)
      Complete with 24-inch blades
      10 HP 230/460/575-volt motor, 3 phase (Single phase optional)
      Capacity Rounds: 2” mild steel rounds
      Weighs approx 2,650 lbs
      120-ton shearing force
      Floor Space: approx 65&… Show More
        Rebuilt Scotty Alligator Shear
        Model SCOTTY #10
        Complete with 10-inch blades
        15 HP 230 volt motor, 3 phase
        Weighs approx 3,000 lbs
        Floor Space: approx 65” x 90”
        Fully rebuilt Hyd. Cylinder hoses,  Limit Switches and Controls repaired valve… Show More
          USED MERCURY 120 BRIQUETTER
          MERCURY 120 BRIQUETTING PRESS
          A high-speed production baler for non-ferrous, cans and light steel applications.  Features include continuous feeding with powerful shearing ram, side compression cylinder, and automatic cycling.  Produces a 12” x 12” x variable length bale at a rate of up to 6-8 tons per hour – depending on the mate… Show More
            USED CSX 2010 CABLE STRIPPER
            Automatic Wire Stripper
            Strip Heavy-Duty Cable from 1/16" - 4-1/2" diam
            • Strip heavy-duty wire 1/16" x 4-1/2" diameter
            • Stripping Speed:110'/min
            • Fully adjustable blade and feed roller assembly
            • Forward and reverse control
            • Automatic safety braking system
            • Separate stripping area for small wire
              Overall Dimension: Approx. 30"x&n… Show More
            Used Guidetti Wire Recycling System
            GUIDETTI SINCRO MILL 415 WIRE PROCESSING SYSTEM
            SINCRO MILL 415 Processing System (for a midsize-large processor, all types of wire and cable especially LOW GRADE) – 75HP motor power - Automated system with PMG600-E pre-shredding machine for simple operation and processing of cable and wire
            MAX INPUT CABLE SIZE – PRE… Show More
            Used Downstroke Balers
            Used Downstroke Vertical Scrap Balers
            Balers designed for light gauge and heavy scrap, Al. extrusion, aluminum cans/bottles, copper, OCC, paper, etc.  These balers are built much heavier with tremendous downforce platen strength offering greater bale density
            MAXPAK Model 6020-66-7 - 7" main cyl, 4.5" rod, 66" stroke, ram pressure = 90,… Show More
              Used Skidsteer Scrap Grapple
              Used (2024) Skid Steer Scrap Grapple c/w dual hydarulic arms, lower bucket with bolt on blade, 73" wide x 34" depth - 24" high.  Comes with quick attach, hyd. hoses and fittings
              Price: $5,600 USD + shipping
                SIGNUP TO OUR NEWSLETTER
                Gensco America Inc.
                5307 Dividend Drive
                Decatur, Georgia, 30035
                United States
                Telephone: 770-808-8711
                Gensco Equipment Inc.
                53 Carlaw Ave.
                Toronto, Ontario, M4M 2R6
                Canada
                Telephone: 416-465-7521
                Fax: 416-465-4489
                View our Privacy Policy
                ©2025 Gensco Equipment (1990) Inc.
                Website by Marketing Blendz
                Cookie Policy
              • softdown
                I usually hope that BB will do his best to solve an issue. Thanks!!!
                My unit needs 18 amps at 230VDC. Quoted data below indicates a need for an ~ 5000 watt generator. That isn’t a problem. But turning the AC into DC is currently a pretty big problem.
                • "82 Cold amps at 230V DC
                • Requires min. 20kW generator”
                Their prices may be on the high end. Judging by this:"Used (2024) Skid Steer Scrap Grapple c/w dual hydarulic arms, lower bucket with bolt on blade, 73" wide x 34" depth - 24" high.  Comes with quick attach, hyd. hoses and fittings
                Still good to see that my magnet may have a value in the low thousands - with some additional parts. Made by Square D a long time ago. I would bet that it has copper windings - not aluminum.
                So I need a large rectifier. Sounds like a good start.
              • softdown
                Then we have this:
                "AC to DC Calculator
                To convert ac voltage to dc voltage enter value in given field by using our ac to dc converter calculator.
                Select Unit (AC / DC):
                                 AC                 DC
                Enter DC Current: 230
                AC Current 361.6352  volts"
                That is three phase voltage. A three phase generator is expensive. Then I also need the large rectifier as well. Sigh.
              • manzanita2
                manzanita2 Registered Users Posts: 31 ✭✭
                You're already finding more info than i did. I did find a list of new smaller magnets:
                They have a 20" dia magnet that takes 900 watts at 90voltsDC so about 10amps?
                They say it weighs 530 pounds and can lift 10,500 pounds. Do you have anything that can lift that much weight high enough off the ground to be useful? Sounds dangerous. I've seen people tip small cranes over being careless.
                Think carefully about your DC-DC conversions. Assuming 100% efficiency,  It would take 100amps @10 volts to create 10amps @ 100 volts. So huge current demands at lower voltages.
                Batteries could be dangerous. You won't know when they are too weak to keep holding your weight! Besides, batteries don't like uncontrolled high current discharges. Any weakness could produce a catastrophic failure. Then you'd have a falling weight and an exploding battery. Be careful!
                Sol-Ark 12, 3 Pytes V5 100ah batteries, currently six REC 420w panels installed. Ten more panels waiting to be installed.
              • manzanita2
                Hah. Looking at downstroke balers brings back memories. We were just creating 700 lb bales of cardboard though. Getting rid of the empty boxes was the easy part.  :)
              • littleharbor2
                littleharbor2 Solar Expert Posts: 2,165 ✭✭✭✭✭
                This reminds me of that episode of Breaking Bad where they use that large magnet to destroy the laptop that's inside the evidence room.
              • softdown
                Good point about weakened batteries losing their grip.
              • Miller_Ranch
                Miller_Ranch Registered Users Posts: 50 ✭✭
