When is my battery bank supposed to charge?
TheVillagesGuy
Registered Users Posts: 10 ✭✭
I have a Schneider Electric Conext SW 4048 AC coupled system with lead acid batteries. I see the battery bank is down to 84% and I am wondering why they are not recharging during the day? I have the charge block set so it does not charge during the evening, but should charge during the day (solar). What am I missing? Thx.
I don't know. Are you using a 24 hour system or 12hr AM/PM ? (set up in the combox & timezone)
Why not recharge batteries from cheap nighttime power ?
Talk to the installer ?
12hr AM/PM.mike95490 said:I don't know. Are you using a 24 hour system or 12hr AM/PM ? (set up in the combox & timezone)
We don't have cheap nighttime power. All one high price. Wanting to recharge from AC solar power during daylight.
I installed myself. -
@TheVillagesGuy
What are your Chg block start and stop time settings? Keep in mind that the start time will disable charging until the stop setting time is reached. Also the charger is automatically blocked while load shaving.
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
I'l bet Raj174 nailed it -It's Start Block and Stop Block, not start charge, stop chargePowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Did this ever get resolved?
I am having same issue without using charge blocks.
