Know how to fix this hydraulic connection?
softdown
Solar Expert Posts: 4,042 ✭✭✭✭
Hose blew off on 55' bucket truck. Must be fixed where it is. Bucket is up and out.
Take the line off and have a new one made. Locally I would go to Mechanic's Bliss but that's not going to help you.
My answer is the same as Steve's. Pull the hose and have one made. Even rural areas have someone who does this because of all of the equipment using hydraulics. In my experience, the pressure is too high to perform a field patch-up without hose-making tools.By the way: That's a nice rig!I always have more questions than answers. That's the nature of life.
Napa makes custom hydraulic hoses.
Quite often shops that service lift trucks will do hose work, and/or farm equipment dealer/shops.
Can you not use a field repair connector to just get the thing back down if you have some slack? (for a field replacement) I don't see any steel braiding. Is this just a return or low pressure bleed off line? It's kind of small diameter for the size of cylinders on that boom.Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
Is that thing still up in the air?
If it is still up there, there, is a great opportunity to place a Grinch inflatable Christmas decoration.littleharbor2 said:Is that thing still up in the air? -
Oops - thought it was a new thread. That's funny. So how did it get fixed?Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
Guess we don't know if it got fixed, so the answer to that is still up in the air.But the Grinch Christmas decoration while up there made me laugh!
Hopefully Softdown isn't still in the bucket. Someone one the ground sent him the pictures and left?Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
Fixed it but the replacement hose was only rated 2250psi. That blew up after a week. Fixed it again.
Terrible but could have been worse. Imagine being 55' up when the hydraulics blow outFirst Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
I believe those two way hydraulics are designed so that they have to be pumped up AND pumped down. Safety feature.softdown said:Fixed it but the replacement hose was only rated 2250psi. That blew up after a week. Fixed it again.
Nothing works at all when a hose blows or engine dies. Pretty dangerous really.littleharbor2 said:
Bucket truck work is not the safest thing in the world.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
