Trace 4024 won't run table saw on new LiFePO batteries
Desert Rat
Solar Expert Posts: 147 ✭✭✭
I installed two new EG4-LL 24V 200Ah batteries a few months ago. When I try to run my 12.8A table saw the inverter shuts off and displays an Overload fault. I also have a 15A miter saw which runs with no problems. I never had this issue with my previous bank of four 225 Ah GC2 LA batteries. Thoughts?
Is the table saw fitted with an induction motor? Most miter saws have a "universal" motor that are more inverter friendly. I'm guessing that the new batteries are dropping voltage when the table saw tries to start.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
Curious!
Doubt it's a voltage drop from the batteries themselves, as lithium don't really drop in voltage much...
...but perhaps new thinner cabling? longer distance wiring over thinner cabling? Did you move your temperature sensitive battery bank into warmed space but leave your power center outside?
Could also be a loose connection, but since the miter saw's working...Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Not sure if you are implying it worked before with lead acid batteries.
LFP batteries have greater peak current sourcing, lower series impedance, compared to lead acid batteries. Your problem may be that batteries are too good, allowing inverter not to have as much DC input voltage slump.
This results in inverter not 'soft starting' AC surge load as much, causing inverter to trip its overcurrent protection. -
Maybe borrow another table saw from a friend to see if you have the same issue? Maybe try a different circuit breaker? Who knows.,,
I am able to run my Dewalt table saw off my LifePo4 batteries, however that’s not exactly apples to apples, due to us having different systems and different saws.Best of luck with solving the mystery.Off-Grid in Terlingua, TX
5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries -
Perhaps Photowit is on the right track. What else has changed since replacing the FLA batteries? A 4024 inverter should easily handle the surge load of the table saw. Unless something happened with the table saw motor? Perhaps you can try the table saw on other system/s?
Perhaps you had a high concurrent load while endeavoring to use the table saw? Perhaps the batteries were not fully charged?
As always, check the DC voltage on the input to the AC inverter--Make sure it is not crashing to 21 VDC or lower during loads/starting surge.
Another quick and dirty--You can use a longer (and/or light weight) extension cord to see if it surge current or something else with the inverter/battery system. The "extra resistance" of the extension cord does reduce starting surge. A trick that sometimes works well on a refrigerator on a smaller AC inverter to reduce starting surge.
More info: I've found that the saw will start and run every time from a cold start. But if I shut it off and try to restart it within a few seconds the inverter will shut down and display the overload fault.
I just ran the saw for a few minutes without shutting it off, and ripped a few boards with no problem. Then when I went back in the house my Dell computer had shut down!
I looked at the logged data on my two Morningstar TS-MPPT-60 controllers to check the minimum battery voltage after running the saw. It showed today's minimum battery voltage to be 27.6V. I had checked it earlier this morning and it was 26.8. So apparently the logged data had reset somehow.
I did talk with a tech at Signature Solar, and his thought was that the BMS was limiting the current from the batteries. -
I forgot; I did try Bill's extension cord trick, but it didn't help.
The Trace failure modes I have seen ( over the decades, as they are getting older ) have never been anything like you are experiencing.
As previously suggested you should try another saw just to eliminate it.
The BMS may be protecting the battery and this battery may not be the choice for you. See what they say and hopefully they will help you."we go where power lines don't" Sierra Nevada mountain area
- 234 Forum & Website
