closed MC4
ws9876
Solar Expert Posts: 453 ✭✭✭
I have a couple panels with MC4 connectors but where the tongs clip in to the female is covered on the sides so you cant use the regular tool to undo them...you can use 2 small screwdrivers together....but..
what is the story on those?
Some MC-4's have squeezable tabs. Maybe?
Years ago, the NEC/UL/NRTL had implemented a requirement that "tools" (screwdriver, wrench, or keys) are required to "access" dangerous electrical circuits (over ~12 to 60 Volt circuits, over 60 volts is definitely "unsafe" for untrained people). So the modern MC4 connector (and the variants) required tools to take apart to prevent children and untrained folks from electrocuting themselves...
The MC4 Tool"
https://www.solar-electric.com/ditoformc4co.html
Was this your question?
The MC4 on Canadian Solar panels,315 watt are definitely different. I have 5 of those tools but CS uses a slightly different size
and design. Its bigger.So I took the Dremel and cut off the blocking tabs and that worked ok. -
Might check your solar panel specs.
Lots of similar to MC4 connectors.
Amphenol H4 connectors
T4 connectors I think used on some Canadian solar panels;
I think Tyco made their own version of solar connector too.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
T4 connectors for Canadian Solar?
https://www.solarpanelstore.com/products/tlian-canadian-solar-male-female-connector-set-t4-pc-1
Tool kit including pair of disconnecting tools:
https://www.solarpanelstore.com/collections/solar-wire-assembly-tools/products/tlian-t4-field-tool-kit-for-canadian-solar-t4-connectors-t4-pc-1
- 234 Forum & Website
