closed MC4
ws9876
ws9876 Solar Expert Posts: 453 ✭✭✭
edited October 2022 in General Solar Power Topics #1
I have a couple panels with MC4 connectors  but where the tongs clip in to the female  is covered on the sides so you cant use the regular tool to undo them...you can use 2 small screwdrivers together....but..
what is the story on those?
  • littleharbor2
    Some MC-4's have squeezable tabs. Maybe?
    Years ago, the NEC/UL/NRTL had implemented a requirement that "tools" (screwdriver, wrench, or keys) are required to "access" dangerous electrical circuits (over ~12 to 60 Volt circuits, over 60 volts is definitely "unsafe" for untrained people). So the modern MC4 connector (and the variants) required tools to take apart to prevent children and untrained folks from electrocuting themselves...
    The MC4 Tool"
    https://www.solar-electric.com/ditoformc4co.html
     Was this your question?
  • ws9876
    The MC4 on Canadian Solar panels,315 watt are definitely different. I have 5 of those tools but CS uses a slightly different size
    and design. Its bigger.So I took the Dremel and cut off the blocking tabs and that worked ok.
    Might check your solar panel specs.
    Lots of similar to MC4 connectors.
    Amphenol H4 connectors
    Amphenol Helios Solar H4 PV Connectors
    T4 connectors I think used on some Canadian solar panels;
    Tlian T4-PC-1 Connector 1500V for Canadian Solar modules - Pair male and  female - TEnergise
    I think Tyco made their own version of solar connector too.
