384 volt lithium-ion battery... for solar storage?
humboolay
humboolay Registered Users Posts: 4
Say one of these 900lb LiFePO monsters was left in a basket on your doorstep one night:
Nominal Voltage: 384 VDC/110 Ah
input charge 20kw; 60 amp max
output 414-348 VDC
Is it a viable option as solar energy storage in a residential setting? Could it be? Should it be? Again, assuming the cost of the battery itself is zero or not far from it. Battery is new as well...
    BB. Super Moderators, Administrators Posts: 33,726 admin
    There is (was?) a push towards 380 VDC powered data centers. Many standard 120/240 VAC computer power supplies can take 380 VDC input power. And for AC inverters, 380 VDC can be more efficiently "switched" to 240 VAC when needed.
    http://dc-nexus.com/wp-content/uploads/2016/01/dcF-THE-BENEFITS-OF-380V-dc-summary.pdf
    If you have the need for lots of power, and can find loads that will take 380 VDC battery bus (plus charging equipment, etc.) it can be used nicely.
    HOWEVER--380 VDC from a large battery bank is also dangerous too. Shock, Arc Flash, etc. are things that somebody not trained and not have the right tools/protective gear (and locked rooms/buildings/etc.) can work support.
    This was a being pushed for data centers 10 years ago or so... Not sure where the industry is at today.
    Dropped on my door step...
    I'd have to check it out. I know the native voltage of LiFePo4 is 3.2-2.6 volts, so it' string of cells to get to that high voltage.
    I'd figure out if I could reduce it safely to 48v nominal strings and look at finding a BMS that would work for it and how many parallel strings would be acceptable.
    humboolay said:
    Is it a viable option as solar energy storage in a residential setting? NOT AS IS, I DON'T KNOW OF ANY AC INVERTERS THAT TAKE 380VOLT Could it be? CERTAINLY IF BROKEN DOWN INTO SMALLER STRINGS Should it be? NOT ON MY DOORSTEP, NOT MY CALL Again, assuming the cost of the battery itself is zero or not far from it. Battery is new as well...
    Big questions...
    Just try getting a 384V MPPT solar charge controller
  • humboolay
    Yeah.. if you happen to come across one in the 400v range let me know! :D
  • littleharbor2
    edited April 2022 #6
    I think he is looking for a 400vdc battery charging output...
    Bill
  • littleharbor2
    Bill
    Here's the specs:
    • Voltage: 384V
    • Max VOC of PV arrays: 700V
    • Max charging current: 100A
    • Inputs: 1 group
    • Equalize charging point: 460.8V
    • Float charging point: 441.6V
    • Over voltage: 512V
    • Over voltage recovery: 480V
    • Equalize charging recovery: 422.4V
    • Stand-by consumption: <.5 Watt
