New on this forum
KennethWilson
KennethWilson Registered Users, Users Awaiting Email Confirmation Posts: 2
I have just joined the forum but would welcome help to find the right/specific forum for wind turbines.
I have a regular PV off grid system running but want help in adding a wind turbine.
    Welcome to the forum Kenneth,
    I am not very strict about which forum to post in... There is the Off Grid & Battery forum, and there is a Wind Turbine forum.
    More or less, if your post/thread focus is on wind turbines--Pick the WT forum. If it more towards the "whole off grid system integration/operation" question--Then the OG and Battery forum.
    Threads can wander too... Don't sweat it.
    Either way--We will do our best to help.
    -Bill "moderator" B.
  • KennethWilson
    Thanks Bill
  • dickie
    dickie Registered Users Posts: 1
    Will a 1200 watt system charge 1040 ah batteries
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,182 ✭✭✭✭✭
    Fieldlines.com: The Otherpower discussion board     This might be a helpful place to look
  • 706jim
    706jim Solar Expert Posts: 527 ✭✭✭✭
    Yes it will. Recommended array size would be larger, but I successfully charged a 660A-hr battery (at 24 volts) with 400 watts of panels. Keep in mind that you are limited in the amount of power you can extract from the battery with this system.
    Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
    Much more complex question than perhaps you think.
    Most of the US is poor for small wind, in most of Scotland I would say yes, in most of the US, I'd say no. In most of the US the wind isn't reliable enough in a range usable to do much. A turbine rated at 1200 watts , might be ratted at 1200 watts at 22knots (just over 25 mph)  So production will be less and often near 0 in most of the country.
    Even in places where there are often considerable wind, it's not consistent enough not to have an equal amount of backup energy source, solar or generator.
    Global Wind Atlas
  • 706jim
    Sorry just noticed you meant a wind turbine not solar array. 1220 watts of wind will charge your battery, but tower height and average wind velocity are major variables.
