New on this forum
KennethWilson
Registered Users, Users Awaiting Email Confirmation Posts: 2 ✭
I have just joined the forum but would welcome help to find the right/specific forum for wind turbines.
I have a regular PV off grid system running but want help in adding a wind turbine.
Welcome to the forum Kenneth,
I am not very strict about which forum to post in... There is the Off Grid & Battery forum, and there is a Wind Turbine forum.
More or less, if your post/thread focus is on wind turbines--Pick the WT forum. If it more towards the "whole off grid system integration/operation" question--Then the OG and Battery forum.
Threads can wander too... Don't sweat it.
Either way--We will do our best to help.
-Bill "moderator" B.Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
Thanks Bill
Will a 1200 watt system charge 1040 ah batteries
Fieldlines.com: The Otherpower discussion board This might be a helpful place to look
Yes it will. Recommended array size would be larger, but I successfully charged a 660A-hr battery (at 24 volts) with 400 watts of panels. Keep in mind that you are limited in the amount of power you can extract from the battery with this system.dickie said:Will a 1200 watt system charge 1040 ah batteriesIsland cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year. -
Much more complex question than perhaps you think.dickie said:Will a 1200 watt system charge 1040 ah batteries
Most of the US is poor for small wind, in most of Scotland I would say yes, in most of the US, I'd say no. In most of the US the wind isn't reliable enough in a range usable to do much. A turbine rated at 1200 watts , might be ratted at 1200 watts at 22knots (just over 25 mph) So production will be less and often near 0 in most of the country.
Even in places where there are often considerable wind, it's not consistent enough not to have an equal amount of backup energy source, solar or generator.
Global Wind Atlas
Sorry just noticed you meant a wind turbine not solar array. 1220 watts of wind will charge your battery, but tower height and average wind velocity are major variables.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
