Show me your Power Center
DavidOH
Solar Expert Posts: 112 ✭✭✭
I am ready to set up my power center where everything comes together. Solar shut off, AC breaker box, DC fuse box, and power distribution. Show me your Power Center. Thanks all !
Time for a new photo, but this is when I was setting up in 2012. Solar arrays come in from behind into the Midnite E-Panel. 2 and later 3 charge controllers on the right. Inverter Prosine 1800, later with an Exeltech 1100 above it for yard work, and now a Magnum 4024 above. Lower right a 12x12 filter to allow air intake and a fan installed in the upper left to exhaust heat. Forklift battery in small enclosure to the right of the Power center.
Wiring for the E-Panel;
My earlier 2004 build, I used scraps to build a battery box and power center cantilevered off the other side. The nearly 4x4 battery box was setup to hold up to 8 L16 batteries with space. I originally had 4 golf cart batteries and later a small forklift battery.
Here is my grid tie setup. First the breaker box with solar meter and AC disconnect required by code at the breaker panel.
Next is the inverters with the DC disconnect and the AC combiner, rewired with hard conduit.
And the panels
My system came Assembled , AIO , its very small and I’m sure I could not of pulled anything thing like this off by my self .The battery box is next store to the rite in the garage .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
This does not show the battery bank.
new xw6848 on the midnight wire box.
new xw60-150 MPPT
old reliable midnight classic 200 w/cover open for more air flow
and a cooling fan for the whole setup on the floor.
When swapping out the old (still going strong) xw6048,
there was very little dust and crud on the fan filters.
I'm still sorting this out.I'm thinking I need a breaker to the inverter for auto-shut off, and a low voltage disconnect just before the DC fuse box.
boB said:
4-Risen 320 watt in series/parallel, 8-215ah 6 volt GC2 batteries in series, Exeltech 1100 watt/48 volt inverter, Tristar 45 MPPT controller. -
Already 9 years! And still the same set of FLA, thanks to this forum and the valuable advice.
Cheers!Off-grid cabin in northern Quebec: 6 x 250 W Conergy panels, FM80, 4 x 6V CR430 in series (24V nominal), Magnum MS4024-PAE
- 230 Forum & Website
