MidNite Solar DIY Series
GaRay
GaRay Registered Users Posts: 1
Anyone used one of the new "all in one" devices where the charge controller, inverter and 120 volt DC charger is one unit? MidNite Solar now makes several of these devices, available at NAWS, as do several other unknown companies. Remember when we purchased separate components for HiFi stereo reproduction then manufactures combined the components... 8 track, cassette and turntable all in one! The quality suffered, IMO.  Is that the case with the new solar "all in one"?
Thanks for your comments!
«1
  • Vic
    edited July 2021 #2
    Here is a video from MidNite on the DIY product line:
    https://www.youtube.com/watch?v=8olwtxjBsvo
    Here is a video on the new MN DIY DIY 60 A MPPT CC:
    https://www.youtube.com/watch?v=_IsfN6S1xoM
      Vic
  • Mike_in_PA
    Mike_in_PA Registered Users Posts: 13 ✭✭
    Does anyone know if the MN3024DIY (and similar) are transformer based?  TIA
    48 GEPV-110, 2 SMA 2500U, 7 AE32s since 2004
  • Vic
    The entire DIY line of inverters,   appear to be High Frequency designs.   Vic
  • Mike_in_PA
    Thanks.  I could not find a weight for the items.
  • Vic
    Hi Mike,
    If the weight still matters to you:
    DIY 3024 weighs 17 Lbs
    DIY 3548 weighs 24 Lbs
    You are correct that the power out vs weight is a very good indicator Low vs High Frequency conversion design.
    Vic
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,182 ✭✭✭✭✭
    Surprisingly inexpensive for Midnite products.
  • mahendra
    mahendra Solar Expert Posts: 191 ✭✭✭
    Yes price seems good. But these units have a scarey resemblance to the Renogy and Powmr which are unreliable chinese brands. I hope its not not the same unit with the midnite name slapped on.
  • Horsefly
    edited July 2021 #9
    Yeah, over on another forum, there's been some pretty certain ident that these are rebranded Chinese items. Kinda sad, but maybe it's OK if Midnite backs them up.
  • boB
    boB Solar Expert Posts: 1,032 ✭✭✭✭
    edited July 2021 #10
    Yes, MidNite offers support for these Chinese inverters and controllers.  They are not Renogy or Powmr.
    China is getting too good at this stuff and with support, it can help a lot of DIY'ers to get into renewables.
    The next group of these will be ETL listed.
  • mahendra
    Well that's a bit comforting to know
  • boB
    Even a Sol-Ark is a Chinese inverter with their name on it   :)  (Deye)
  • mahendra
    Yes .Another post indicated the same Deye.has good reviews in austrialia
  • MichaelK
    MichaelK Registered Users Posts: 236 ✭✭✭
    edited July 2021 #14
    One of the statements Midnight makes about the unit is that it has "excellent surge capacity".  I've gone through the whole manual and find no reference to what that capacity is?  Is it 200% for 5 seconds, or 200% for 16 milli-seconds?  I'm more inclined to believe it's 16 ms?
    They do mention that the unit can start a "2hp loaded motor", but they in no way indicate what that starting surge is?
    I'm guessing that this unit would be a good choice for powering a garage or other secondary structure, but not where you'd be expecting to run motor-driven power tools, compressors, ect.  That would need a stout low-frequency inverter like a Radian or Conext/XW.  Will be OK powering a cabin where you just need cold beer to watch TV.
    System 1) 15 Renogy 300w + 4 250W Astronergy panels,  Midnight 200 CC, 8 Trojan L16 bat., Schneider XW6848 NA inverter, AC-Delco 6000w gen.
    System 2) 8 YingLi 250W panels, Midnight 200CC, three 8V Rolls batteries, Schneider Conext 4024 inverter (workshop)
  • boB
    I haven't seen this.   Do you remember where you saw/heard this ?
    I do know that the new MidNite inverters are surging like crazy in house  though !
  • MichaelK
    edited July 2021 #16
    It's in the brochure.  If you click on the link above, two sub links down the page are the product brochure, and the product manual.
    Tried to do a cut and snip, but it didn't show up in the response.
  • mahendra
    Well I have been pretty skeptical of Midnite's DIY stuff and a matter of fact all of the new Chinese inverter ,but I must say that there are several brands such a growwatt,phocos, deye etc that are high frequency but matches the surge performance of low frequency inverters.
    It's just technology improvements real
  • boB
    Yes, China is getting WAY too good at this stuff !   They still miss the boat on some aspects though and the US, Germany, etc will still have their place.  At least I hope so !
  • Saggys
    Saggys Solar Expert Posts: 189 ✭✭✭
    Will Midnite Solar have a prewired e-panel available for the DIY line?
    I think much of it is integrated into the Unit, As it contains charge controller, transfer switch, you might be better off wiring a small box for a big inverter breaker and a PV input breaker.
  • Saggys
    AC output and generator bypass would be nice also. That could also be done externally. Sure would keep the footprint small with an e-panel.
  • mahendra
    Formxwhat Midnite is saying on their forum ,they will .
  • Saggys
    mahendra could you provide a link? I could not find any talk of an e-panel getting developed for the DIY series.
    Here is one thread:
    http://midniteftp.com/forum/index.php?topic=5190.0
    And a neat trick for Google/duck duck/bing/etc. search engines. The "site:" tag to limit searches to a specific website/address:
    site:midniteftp.com/forum/ diy epanel
    Results using Duck Duck:
    https://duckduckgo.com/?q=site:midniteftp.com/forum/+diy+epanel&ia=web
  • Saggys
    Thanks Bill!
  • Saggys
    The DIY series inverters do not have a high enough absorb voltage setting to accommodate all battery chemistries such as NIFE. I would think adding a few more volts in the software wouldn't be all that hard?
    My XW inverter does not have high enough voltage, but with NiFe, I don't have to fully charge them, my PV controllers can get them all the way full when the sun eventually returns
    It requires better internal equipment too handle larger voltage ranges. I suspect making it inexpensively requires/necessitates the minimal range. I understand Most inverters can't handle the wide range due too the inefficient charging nature of NiFe batteries. At around 65%  efficiency, I always recommend people avoid them for solar electric systems. I think only Magnum and some Schneider inverters have the range for NiFe.
  • Saggys
    My old Trace PS series will do up to 33 volts input which should safely get me 32.4 v on the charge controller, at least I hope it will, should know shortly.
  • Vic
    edited August 2021 #30
    Here is a quick (six minute) video,  by Halfcrazy Ryan,  demoing the MN3548DIY inverter,  powering his home:
    https://www.youtube.com/watch?v=mOPnHyDAjcc
    Vic
  • Saggys
    Thanks Vic, nice video.
