Flooded Battery Bank Placement
nbaker
nbaker Registered Users Posts: 8 ✭✭
My bank is 5 (12V) batteries in parallel.  I am setting up the system now and was planning to put these in the garage floor (attached garage) due to off gassing, however all my equipment is on the basement wall (next to the service panel) and I'd like your opinion of placing the batteries in the basement as well.  Wire length is not an issue either way because charge controller and inverter (on basement wall) are only 2-3ft from where the batteries are in the garage (floor).  My concern with basement was the gassing during charges.  This basement room is about 15' x 27' not really ventilated, but it does have the nat gas furnace and water heater.  My solar equipment and furnance are about 20 ft apart.  Garage is less secure and is subject to temperature fluctuations between 35 - 95 degrees depending on the season.  Basement or garage folks?!?!
    BB. Super Moderators, Administrators Posts: 33,695 admin
    My first suggestion is to read this website on how to parallel batteries and better balance charging and discharging:
    Second, any battery system in the house--Have you looked at fusing/breakers for your battery system to reduce the chance of fire from overheated cables (short circuits, etc.)?
    Temperature wise, a basement is usually a good place for batteries because of the stable temperatures... Below ~50F, Lead Acid batteries do lose (only when cold) some capacity. And for every 10C or 18F over ~25C/75F, batteries tend to age 2x faster (i.e., at ~93F, a battery will only last 1/2 as long).
    Have you looked at battery box with some venting? Lead Acid batteries do output some Hydrogen gas and electrolyte mist. Some folks are very sensitive to the "rotten egg" smell of sulfuric acid. And the mist can settle on other stuff you may have in the basement around the batteries.
    Lead Acid and even AGM/Sealed batteries, as they age, more gassing happens (as well as during EQ charging of FLA batteries and AGM batteries near end of life). So boxing/venting is a good idea anyway for long term installations.
  • softdown
    softdown Solar Expert Posts: 3,963 ✭✭✭✭
    Heat kills batteries pretty fast. I suspect that many of our stories about short battery bank lives are related to batteries suffering from temperatures over 90F for prolonged periods. One poster even built a water tight battery box with a chiller to keep the water cool. He never reported back to my knowledge. in theory - it seemed sound.
    I've never suffered many of the reported problems from battery off gassing. People sometimes talk of strong odors etc. I wonder if they are reading what others have read what other have wrote instead of actually seeing it. In fact I will double down and note the presence of a lead acid battery under the hood of almost every automobile on the road. A battery that often receives a high rate of charge while in the proximity of the engine. Yet most of us have oddly survived this certain disaster - to date.
    Though a neighbor did somehow manage to blow up a lead acid battery. I have no idea what procedure he was engaged in. An experiment of some type I might guess.
    A gassing battery in a basement with ignition sources is a hazard.  The batteries need to be in a vented box
    Hydrogen is explosive at 4% .  In your basement, that would be catastrophic.
    https://en.wikipedia.org/wiki/Hydrogen_safety
      excerpt "Hydrogen collects under roofs and overhangs, where it forms an explosion hazard; any building that contains a potential source of hydrogen should have good ventilation, strong ignition suppression systems for all electric devices, and preferably be designed to have a roof that can be safely blown away from the rest of the structure in an explosion. It also enters pipes and can follow them to their destinations. Hydrogen pipes should be located above other pipes to prevent this occurrence"
    edited August 2020 #5
    I live in Missouri, and just accept that the batteries will get warm over summer. I much prefer having my battery bank and power center outside. The large thermal mass of the forklift battery helps reduce the fluctuation. Still I try not to equalize the battery over summer. We actually had a couple night at 60 or below and I was suppose to equalize today but forgot. It's 9 years old and it's been a particularly bad summer with several hot overcast days, so the battery has been run down lower than past summers, but it's hung in there pretty well.
    That said, I've been looking the cleverly designed array for taking out a couple panels so a tow truck or large tractor can lower a new one into place with only having to remove 2-3 panels. Glad I thought ahead. Hope to make it to 12 years, but time will tell.
  • softdown
    Well there is an ancient and proven technology called - digging a hole. This invariably provides cooler temps but modern man can hardly be bothered with such a cumbersome chore. Says the guy who keeps putting off the need to get his backhoe running. I'll get a round tuit - someday.
    I'd say ideal battery temps lay between 40F and 70F.  Ideal is rarely practical of course.
  • nbaker
    I decided to keep these in the garage, with only a 4 ft run into the inverter on the basement wall. Safety > battery efficiency.
  • Phazor
    Phazor Registered Users Posts: 2
    How has this worked out for you? I am considering the same thing but with 16 6volt batteries.
  • 706jim
    706jim Solar Expert Posts: 523 ✭✭✭✭
    To the OP if he is still around, Trace specifically recommended not having the inverter in the same compartment or general area as batteries due to the corrosive effect of off gasses during charging.
    I keep my batteries outside in a vented enclosure.
  • wellbuilt
    wellbuilt Solar Expert Posts: 763 ✭✭✭✭
    I would not keep battery’s in the same room with my equipment .
     my battery’s are in a box next to the utility  room  in the garage with my floor sloped to the out side
      The box is sized for l 16s so I can have more AHs if I need more power .
    I live the lid open 2” if it gets warm in the box but generally my battery’s stay around 75 77o in July and August .
     There is a power vent running out the wall .
      At 0o the battery’s stay around 45 50o
