Car starter battery and AGM auxiliary battery in parallel
Matty
Registered Users Posts: 36 ✭✭
I would like to setup a dual battery system in my car to power 12V appliances while driving and also while stopped. My car has a temperature compensating alternator and an ignition relay which disconnects the starter battery when the ignition is switched off. An auto electrician advised me to simply connect my car starter battery and 120Ah AGM auxiliary battery in parallel and power the appliances from the auxiliary battery. The idea is that the auxiliary battery will maintain a high state of charge by receiving charge from the starter battery while the ignition is on and isolate the auxiliary from the starter battery when the ignition is switched off. I asked whether this type of alternator could cause the voltage to drop too low to keep the auxiliary battery at 100% state of charge and his opinion was that yes this is true but it would likely still reach 95% SOC which is acceptable for me. My question is related to whether this is good practice. There are differing opinions. Some say that it is fine to place a car starter battery and an AGM battery in parallel and others say batteries should only be connected in parallel if they are of the same type, age and capacity. I am wondering whether this setup is a good one or whether I should add a DC-DC charger between the car starter battery and auxiliary AGM battery.
This is a complicated subject which really needs thought, flooded starting batteries and AGM deep cycle batteries have different requirements, particularly when it comes to charging voltage. AGM require a slightly lower charging voltage to prevent venting, whereas flooded starting batteries accept a higher voltage for a brief period after doing their primary task, supplying a brief high amperage load.
When connected in parallel each battery will experience both loads and charging they weren't specifically designed for, which is a recipe for disaster, in my opinion. Keeping them seperate doing their intended purpose is the best advice I can offer.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
mcgivor said:This is a complicated subject which really needs thought, flooded starting batteries and AGM deep cycle batteries have different requirements, particularly when it comes to charging voltage. AGM require a slightly lower charging voltage to prevent venting, whereas flooded starting batteries accept a higher voltage for a brief period after doing their primary task, supplying a brief high amperage load.
When connected in parallel each battery will experience both loads and charging they weren't specifically designed for, which is a recipe for disaster, in my opinion. Keeping them seperate doing their intended purpose is the best advice I can offer. -
A DC-DC charger must be configurable for your auxiliary battery style ( AGM )
it will also have some losses, figure about 15% loss, so if you are charging 15A, you are consuming 17.25A from the vehicle
Matty. It’s a simple process if you use a battery isolator like this: https://hellroaring.com/
I’ve put these in both my pickup trucks, including a 2018 F150 that is loaded with electronics.The isolators are solid state and made in the USA by Hellroaring. They will field phone calls to walk you through the process.It will take you less than a day to install. The hardest part is deciding where to put the sux battery.Off-Grid in Terlingua, TX
Wheelman55 said:Matty. It’s a simple process if you use a battery isolator like this: https://hellroaring.com/
- 228 Forum & Website
- 618 Discussion Forums/Café
