Android ver 10 wi-fi behavior
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
Bummer. I have found that android ver 10 and latest Chrome browser, do not like a private wi-fi island and will refuse to communicate to it.
When connected, wifi announces "qualifying internet connection" ( or something like that ) and since there is no internet, only a stand-alone router, the wifi never qualifies the connection.
( i got a new phone, and the new phone won't connect to the existing router) So in the meantime, i'm using the old phone, but it's battery is on it's last legs (sealed case, not easy to open to swap battery).
Anyone else come across this issue.
phone wifi -------> wireless router <---- charge controllers w/fixed IP address , combox w/fixed IP address
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Nothing specifically with your Android private wifi network problems--But is a link with some of the basic things to "fix" the no internet error in general (may allow you to connect anyway):
https://techviral.net/wifi-connected-but-no-internet-on-android/
https://androidforums.com/threads/connect-to-home-wifi-without-internet.1014094/ (pre Android 10--May not apply now)
https://android.stackexchange.com/questions/131132/force-marshmallow-to-keep-a-wi-fi-without-internet-access (android 6)
It looks like deleting the wifi connection on the phone and then refinding/connecting seems to be typical answer (for some folks).
Otherwise, can you just get a small USB power bank to use with the old phone (won't be as portable--but would work).
So, when I connect to an AP where there's no Internet access, Android 10 will pop up a notice after 10-15 seconds, which offers the opportunity to stay connected anyway (and remember that choice, if desired). Works fine.
Thanks Bill, I think your first link looks the most promising, and I'll try it this weekend
Geez, when did Android start naming versions with numbers instead of candies and cakes?
Android 9 Pie, Android 10 (Q) -- I guess they gave up on the desert name and did not use Q much... Android 11 no name...
Thanks Bill
I think my earliest android version was called Dirt.
