MPPT60 FAULT code F71
zxmedic
Registered Users Posts: 3 ✭
I am new here hello all
I've been getting Fault code F71 on my solar controler at night or when gen is charging my battery bank the code only last a few secs . Cabling is correct size Batts all test great on the specific gravity anyone run into this issue and a Fix ?
several companies make a MPPT60.. What is yours ? What does your manual say F71 is ??
Schiender the code states DC overload
I've found a post on this sort of issue and it possible needs a firmware update ?
