tittiger: Problems with two Outback FM80s tied to one battery bank
Posts: 93 admin
It seems as if I am not the only one to attempt this. I went to the Flexmax 8o page and sadly not a darn thing to guide the purchaser in this matter that does not seem to be rare.
This thread did little else but confuse me. No one went over to Outback and got their advice and put it here.. If I can't get these to work it's going to cost me $1500 to fix the problem. Lack of product basic information on on the web site has cost me $$$$ multiple times and it's frustrating as hell.
Is it too much to ask to get good/complete info on the products that we buy?
Welcome to the forumtittiger said:It seems as if I am not the only one to attempt this. I went to the Flexmax 8o page and sadly not a darn thing to guide the purchaser in this matter that does not seem to be rare.
Is it too much to ask to get good/complete on the products that we buy?
Perhaps you should start a new discussion explaining your particular issue, this will be more effective in getting responses than a 7 year old thread. There are many hear now who have experience with the Flexmax controllers that may not have been members back then.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
We are all responsible for learning about the equipment we purchase. You might find some more info by asking on the Outback Forum Here;tittiger said:It seems as if I am not the only one to attempt this. I went to the Flexmax 8o page and sadly not a darn thing to guide the purchaser in this matter that does not seem to be rare.
https://forum.outbackpower.com/
Likely you aren't in such a bad position. Before the system voltage reaches close to the bulk/absorb point, both charge controllers should work properly. That's 80% full, then if one cut out, the batteries will start allowing less current to flow into them (assuming lead acid batteries).
Bill might split this off into it's own subject. Might make 1 reply so he knows it's not just a waste of time.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
