Need Recommendation for "Quiet" Inverter
2»
  • jmb
    jmb Registered Users Posts: 42 ✭✭
    Vic - Yeah, had asked on QRZ a year or so ago and didn't get much satisfaction.  Now that running the AC line to the breaker panel in conduit has significantly diminished maybe I don't have to be so picky.  Next time I have the breaker panel cover off I'll see if I have a mix 31 to replace the mix 43 with.
    Justin B.
    Cabin - 9 Mission Solar 310 watt panels, MidNite Solar Combiner, Iron Ridge mounting, 4 Speciaized Power 200 AH 24V LiFePO4 batteries, Samlex PST-1500-24 inverter, MidNite Solar Classic 200SL CC
    Barn - 9 Renogy 100W panels, Generic Chinese 40A MPPT CC, 6 Universal 12V 100 AH AGM batteries, Reliable 3KW 12V PSW inverter
  • Vic
    That IS most excellent Justin.
    Please let us know how things are going.  Be safe,  73  GL,  VIc
  • jmb
    Guess I bragged too soon.  Yesterday I fired up the radio and my inverter hash was back.  the only thing different is that we got 6" - 8" of rain over about 4 days so the ground is 1oo% saturated. I have at least been able to get on 20M and work the West Coast the past couple of days...  I wish I had an O-Scope up here...
    Justin B.
  • jmb
    I removed the three turn mix 43 choke and spliced in 12 turn mix 31 choke.  Don't see a whole lot of difference...
    Justin B.
  • Vic
    Hi Justin,  Thanks for the pic.
    If it is easy,  please try removing about half of the turns on that toroid,   and note any difference.   That is a very large core,   and is quite useful,  when dealing with large gauge cable.
    As boB,   and others have noted,   it is quite possible to have so many turns on a core,   that there is coupling twix the windings,   which can create more RFI,  compared to fewer turns on that core.   Also,  it is often a good idea,  to try to space the turns around the core,  such as to try to minimize this coupling.
    IMO,   73,   Good Luck,    Vic
  • jmb
    Not that big, really, ft240-31 with 12ga solid...  Will make another and save this one for a balun...
    Justin B.
  • mcgivor
    @jmb Have you tried using an isolation transformer between the source and radio?
  • jmb
    Radio is running off DC, straight off the battery bank.
    Justin B.
