Need Recommendation for "Quiet" Inverter
Vic - Yeah, had asked on QRZ a year or so ago and didn't get much satisfaction. Now that running the AC line to the breaker panel in conduit has significantly diminished maybe I don't have to be so picky. Next time I have the breaker panel cover off I'll see if I have a mix 31 to replace the mix 43 with.
Justin B.
Cabin - 9 Mission Solar 310 watt panels, MidNite Solar Combiner, Iron Ridge mounting, 4 Speciaized Power 200 AH 24V LiFePO4 batteries, Samlex PST-1500-24 inverter, MidNite Solar Classic 200SL CC
Barn - 9 Renogy 100W panels, Generic Chinese 40A MPPT CC, 6 Universal 12V 100 AH AGM batteries, Reliable 3KW 12V PSW inverter -
That IS most excellent Justin.
Please let us know how things are going. Be safe, 73 GL, VIcOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Guess I bragged too soon. Yesterday I fired up the radio and my inverter hash was back. the only thing different is that we got 6" - 8" of rain over about 4 days so the ground is 1oo% saturated. I have at least been able to get on 20M and work the West Coast the past couple of days... I wish I had an O-Scope up here...Justin B.
I removed the three turn mix 43 choke and spliced in 12 turn mix 31 choke. Don't see a whole lot of difference...Justin B.
Hi Justin, Thanks for the pic.
If it is easy, please try removing about half of the turns on that toroid, and note any difference. That is a very large core, and is quite useful, when dealing with large gauge cable.
As boB, and others have noted, it is quite possible to have so many turns on a core, that there is coupling twix the windings, which can create more RFI, compared to fewer turns on that core. Also, it is often a good idea, to try to space the turns around the core, such as to try to minimize this coupling.
IMO, 73, Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Not that big, really, ft240-31 with 12ga solid... Will make another and save this one for a balun...Justin B.
@jmb Have you tried using an isolation transformer between the source and radio?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Radio is running off DC, straight off the battery bank.Justin B.
- 425 Caravan, Recreational Vehicle, and Marine Power Systems
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
