Solar insolation in space
littleharbor2
Was watching the NASA Channel last night and one segment they were talking about the solar panels they use to create electricity in  space. While they didn't mention it , it piqued my curiosity as to how much insolation they can get in the vacuum of space. In perfect and exceptional situations we can get 12-1300 watts per square meter, maybe more on earth. Anybody know what they get in space?
  • mcgivor
    Interesting question, since altitude affects the isolation ir would be logical to assume outside the atmosphere it would be greater but also dependant on the distance from the sun itself. https://www.pveducation.org/pvcdrom/properties-of-sunlight/solar-radiation-in-space
  • Horsefly
    From NOAA (https://www.ngdc.noaa.gov/stp/solar/solarirrad.html) there is the following graph.  Looks to me like 1366 Watts per square meter is pretty average. Insolation and irradiance are - as far as I can tell - synonymous. Irradiance is used when discussing space.
  • RCinFLA
    About 20% more,  There is a lot more radiation in UV part of spectrum.
    This high UV rad would accelerate the degradation of your normal earth bound PV panels, increasing their shunt leakage current.  Earth surface UV-A and UV-B radiation is a dominate reason for the 0.5% to 0.9% drop in PV panel output per year.
    I heard it was a limiting factor for space station staying time on the first SpaceX crewed Dragon mission as the PV cells on the trunk section were not super UV resistant and degraded relatively quickly over time.  The next crewed Dragon will have better (and more expensive) UV resistant PV cells.
    edited August 2020 #5
    Compared to solar noon on a cool/clear day which is around 1,000 Watts/sm.
    "Energy" in solar radiation is a bit more complex than just W/sm... We use 1,000 W/sm for how much energy a solar panel can harvest (at around ~15% average efficiency). Since solar panels really only use visible light, the long wave (heat) and shortwave (UV) radiation part of the energy spectrum is not useful. The atmosphere does a good job of stopping most of the shorter wave lengths (UVB and UVC).
    Nice chart of Edge of atmosphere vs a sea level:
    https://ecotality.com/can-solar-panels-work-with-artificial-light/
    solar radiation spectrum
    And solar panel conversion ranges:
    efficiency vs wavelengths of different solar panel technologies
    Dave Angelini Solar Expert Posts: 7,081 ✭✭✭✭✭✭
    More power and more power longer because they track it on the ISS.
    Spent a few years looking at the manuals.
    The last I heard from last week was the americans are bunking in the russian section of the ISS. Trying to find a leak that was increasing in their section.
  • littleharbor2
    Cool, thanks for all your replies. I would have thought the numbers would've been higher. I must admit I didn't try to find this out online cuz I figured you guys are smarter than a lot of what might be out there in cyber land. You know, You Tube and all.
    If you are in the land of clear skies (offgrid without smoke) one of the great things in life is to watch the ISS go over you. Here is a link.
    https://spotthestation.nasa.gov/
  • littleharbor2
    Thanks Dave. I am in Baja full time now. There's a guy within VHF radio range who always announces a couple hours before fly overs the time and direction of travel. I will save this link all the same.
    Ah the baja coconut telegraph is alive and well ! Ever listen to 80 meter Sonrisa net? There was an ISS astronaut on there last year.
    Save me a pacifico! Enjoy !
  • littleharbor2
    No 80 meter. Plenty of icy coldies though. If you ever get down this way give me heads up.
    Definitely !
