Solar insolation in space
Interesting question, since altitude affects the isolation ir would be logical to assume outside the atmosphere it would be greater but also dependant on the distance from the sun itself. https://www.pveducation.org/pvcdrom/properties-of-sunlight/solar-radiation-in-space
From NOAA (https://www.ngdc.noaa.gov/stp/solar/solarirrad.html) there is the following graph. Looks to me like 1366 Watts per square meter is pretty average. Insolation and irradiance are - as far as I can tell - synonymous. Irradiance is used when discussing space.
Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 8S (25.6V), 230Ah Eve LiFePO4 battery in a custom insulated and heated case. -
About 20% more, There is a lot more radiation in UV part of spectrum.
This high UV rad would accelerate the degradation of your normal earth bound PV panels, increasing their shunt leakage current. Earth surface UV-A and UV-B radiation is a dominate reason for the 0.5% to 0.9% drop in PV panel output per year.
I heard it was a limiting factor for space station staying time on the first SpaceX crewed Dragon mission as the PV cells on the trunk section were not super UV resistant and degraded relatively quickly over time. The next crewed Dragon will have better (and more expensive) UV resistant PV cells. -
Compared to solar noon on a cool/clear day which is around 1,000 Watts/sm.
"Energy" in solar radiation is a bit more complex than just W/sm... We use 1,000 W/sm for how much energy a solar panel can harvest (at around ~15% average efficiency). Since solar panels really only use visible light, the long wave (heat) and shortwave (UV) radiation part of the energy spectrum is not useful. The atmosphere does a good job of stopping most of the shorter wave lengths (UVB and UVC).
Nice chart of Edge of atmosphere vs a sea level:
https://ecotality.com/can-solar-panels-work-with-artificial-light/
And solar panel conversion ranges:
More power and more power longer because they track it on the ISS.
Spent a few years looking at the manuals."we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
The last I heard from last week was the americans are bunking in the russian section of the ISS. Trying to find a leak that was increasing in their section."we go where power lines don't" Sierra Nevada mountain area
Cool, thanks for all your replies. I would have thought the numbers would've been higher. I must admit I didn't try to find this out online cuz I figured you guys are smarter than a lot of what might be out there in cyber land. You know, You Tube and all.
If you are in the land of clear skies (offgrid without smoke) one of the great things in life is to watch the ISS go over you. Here is a link.
https://spotthestation.nasa.gov/
Thanks Dave. I am in Baja full time now. There's a guy within VHF radio range who always announces a couple hours before fly overs the time and direction of travel. I will save this link all the same.Dave Angelini said:If you are in the land of clear skies (offgrid without smoke) one of the great things in life is to watch the ISS go over you. Here is a link.
https://spotthestation.nasa.gov/2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
Ah the baja coconut telegraph is alive and well ! Ever listen to 80 meter Sonrisa net? There was an ISS astronaut on there last year.
Save me a pacifico! Enjoy !"we go where power lines don't" Sierra Nevada mountain area
No 80 meter. Plenty of icy coldies though. If you ever get down this way give me heads up.Dave Angelini said:Ah the baja coconut telegraph is alive and well ! Ever listen to 80 meter Sonrisa net? There was an ISS astronaut on there last year.
Save me a pacifico! Enjoy !2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
Definitely !"we go where power lines don't" Sierra Nevada mountain area
- 232 Forum & Website
