Optimal time for Equalization
softdown
Solar Expert Posts: 4,081 ✭✭✭✭
Last time I did it in well into Float with an external charger. Got a "vibe" that my timing was off.
Isn't it best to Equalize some time in Absorb? Photowit does this procedure every month - hope he is around.
IMO, when to equalize is best determined by measuring how unequal it is.
Would suggest EQing FLA batteries at the very end of Absorb, or just after Float begins, as recommended by a number of FLA manufacturers.
Off Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
