A true solar friendly 9 cu. ft. fridge that uses about 200 kWh/year.
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
Expensive ($1000) compared to other small economy units but very miserly in energy usage. Runs on 12/24 DC volts.
2.7" of insulation for the freezer with no defrost built in. That is the secret.
Reviews are generally good as fridge reviews go. I do wonder if the failures were related to issues with insufficient panels and batteries. Not one reviewer demonstrated significant knowledge about that subject. One noted that it worked off just two regular marine deep cycle batteries - which is really very little.
Off topic but we have a Unique propane fridge that has worked great for us, very reliable. Bought it used and it is on its fifth year for us.
Saggys said:Off topic but we have a Unique propane fridge that has worked great for us, very reliable. Bought it used and it is on its fifth year for us.
Pretty on topic - same brand
A local supplier was offering either this fridge or a similar one. Price was $1800 CDN. Runs on 12 or 24 volts DC
Pros: No inverter needed, low power consumption about half that of a conventional fridge.
Cons: high cost and lack of defrost cycle; reliability long term is unknown. difficulty getting service
This would be a good choice if you are running a dinky solar system.
But I would consider the alternative of a larger solar setup and a cheaper conventional fridge. I used to HATE defrosting my propane fridgeIsland cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year. -
I agree on defrosting the propane freezer and not to mention the occasional flue cleaning. A small sacrifice for turn it on and forget about it. This is used in our bunkhouse which only has 160 watt pv and 300 watt morningstar inverter.
It is an extreme to be sure. I have literally never defrosted a freezer - to my memory anyway.
Changing the subject for sure - When my 3648 inverter goes out, I am interested in replacing it with a 1500 watt inverter. I bought a case of them thinking I would do simple cabin solar installations. Big inverters can be the largest energy consumer of them all I suspect. Yet we never post actual numbers regarding specific inverter energy usage.
26w or 28w for the big onesoftdown said:....... Big inverters can be the largest energy consumer of them all I suspect. Yet we never post actual numbers regarding specific inverter energy usage.
That is interesting considering the figures I've recently seen bandied about - like a steady 100 watts. Perhaps the idle consumption/no load rarely happens in the real world of powering a typical home.
FWIW my pure sine aims 300 watt inverter uses 0.7 amps just being on.
I tested it showed 8 watts.
2kw array 6 345 q cells make sky blue 60 cc
6 230ah GC @36 volts
18 amp accusense charger. 3650 champion -
Thanks - amps can be a little misleading when dealing with 12 and 24 and 48 volt units. 8 watts is nothing.
Yea, small inverters are like small engines. Idle with much less fuel. My Prius was left on overnight and hardly used fuel. It dies weird things due to the hybrid battery interface.
Comparing Mike's conext to my aims his is roughly 20 times bigger with only 3 times the amount of idle consumption. Looks like its sipping power.
To bring the conversation back to fridges, my 14.5cuft inverter LG uses about 330kwh/yr and maxes out at 260 watts (more to defrost?) on the killowatt meter. Usually it sits somewhere between 60 and 90 watts. I believe it could run on a MS300 inverter, but My dependable outback 3048 idles at 24 watts. I agree with Softdown, given these new appliances I believe smaller more efficient inverters are the way ahead.Outback Flexpower 1 (FM80, VFX3048E-230v, Mate, FlexNetDC) 2,730watts of "Grid-type" PV, 370 AmpHrs Trojan RE-B's, Honda 2000 watt genny, 100% off grid.
But...to follow on from my post above...the problem has always been, where does one find a higher nominal voltage, lower watt, inverter? Softdown, did you find a case of (reliable manufacturer) efficient low wattage 48v inverters?softdown said- When my 3648 inverter goes out, I am interested in replacing it with a 1500 watt inverter. I bought a case of them thinking I would do simple cabin solar installations.Outback Flexpower 1 (FM80, VFX3048E-230v, Mate, FlexNetDC) 2,730watts of "Grid-type" PV, 370 AmpHrs Trojan RE-B's, Honda 2000 watt genny, 100% off grid. -
Small 48volt inverters are more available now as low as 250 watts. Outbacks 1548. 1500 watts.
thing is just because its lower watts
Does not have much less idle.
Pretty sure my Trace 1524 runs at 8 watts; less on standby mode. And has been running 24/7 since 1994. I've thought about replacing it with a pure sine inverter, but could I get this sort of reliability?Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
