MAGNET STRENGTH
GANNY
Registered Users Posts: 7 ✭✭
I had used N35 magnet in the construction of my magnet rotor. I now intend to use N42. What is the PROS and CONS on the efficiency of my wind generator if I use magnet of higher strength ? Is the RPM of the blades going to be reduced? Your answer will be HIGHLY APPRECIATED as I about to buy the new magnet N42 THANKS IN ADVANCE
I'd expect a stronger magnet to have more influence (drag) on the coils and would slow the turbine down in the same speed wind, with the same LOAD on the output. A lot has to do with the load your batteries present the turbine, no load = higher RPMs (till it overspeeds and destroys itself) More load = lower RPM's (often a dead short, applied in stages, is used to slow a turbine)
So you go to your design nomograhms and see what happens.
Field strength determines max amps, speed determines voltage.
