Charge controllers: Rated by input or output amps???
Montanaclan
Montanaclan Registered Users Posts: 9 ✭✭
I'm finding conflicting information on this... I'm looking at using an MPPT controller to use some cheap used 24v panels and feeding a 12v battery bank on an RV.   If controllers are rated by input amperage, a 20 amp controller should be fine.   If rated by output amperage, I'll need a 40.    There must be a definitive answer available from this group... help!   Many thanks.
  • mcgivor
    Rated by maximum output............best not to run at maximum though.
  • Montanaclan
    @mcgivor
    Ok... so if I'm running 2 * 275w panels in parallel that spec at ~9 amps each, not accounting for de-rating (in order to be conservative on controller needs).... I'd have about 31v at 18 amps going in, and would have about 46 amps at 12v coming out... so I should go with a 60 amp MPPT controller?
    Thanks again - the help is really appreciated.
  • mcgivor
    The rated output of the panels will unlikely ever be seen unless in perfect conditions, freezing temperatures in full sunlight, the normal output will be in the 75-80% range so ~35A, having a controller with more potential capacity would allow for some expansion as well as putting less stress on its components.
    The rough math:
    • 2 * 275 Watt panels * 0.77 panel+controller deraring * 1/14.5 volts nominal charging = 29.2 Amps on cool/clear day/noonish
    That would be about the best I would expect to see spring/fall clear days.
    • 2 * 275 Watt panels * 1.0 cold panels * 1/14.5 volts = 37.9 Amps winter peak
    Given that you are in/around Montana (?), then in very cold/sub freezing weather, you could see more.
    It is one of those things... You probably get 20% more power in deep winter, but your actual harvest time is pretty short in winter.
    And your maximum current is during cold weather--So that is "better" for running near full power...
  • 706jim
    706jim Solar Expert Posts: 526 ✭✭✭✭
    So 40 amps should do it.
  • Montanaclan
    That’s great. And even better to learn about the cold panel performance. On the on hand we have a lot of cloudy winter days, on the other, I’d need more power in the cold season due to furnace cycling.  ... all this to power a small rv, with my cpap as the single biggest draw.  Thanks!
    Yes.
    PWM controllers rated INput amps
    MPPT  rated by OUTput amps   Enjoy
