Charge controllers: Rated by input or output amps???
Montanaclan
Registered Users Posts: 9 ✭✭
I'm finding conflicting information on this... I'm looking at using an MPPT controller to use some cheap used 24v panels and feeding a 12v battery bank on an RV. If controllers are rated by input amperage, a 20 amp controller should be fine. If rated by output amperage, I'll need a 40. There must be a definitive answer available from this group... help! Many thanks.
Rated by maximum output............best not to run at maximum though.Montanaclan said:I'm finding conflicting information on this... I'm looking at using an MPPT controller to use some cheap used 24v panels and feeding a 12v battery bank on an RV. If controllers are rated by input amperage, a 20 amp controller should be fine. If rated by output amperage, I'll need a 40. There must be a definitive answer available from this group... help! Many thanks.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
@mcgivor
Ok... so if I'm running 2 * 275w panels in parallel that spec at ~9 amps each, not accounting for de-rating (in order to be conservative on controller needs).... I'd have about 31v at 18 amps going in, and would have about 46 amps at 12v coming out... so I should go with a 60 amp MPPT controller?
Thanks again - the help is really appreciated. -
The rated output of the panels will unlikely ever be seen unless in perfect conditions, freezing temperatures in full sunlight, the normal output will be in the 75-80% range so ~35A, having a controller with more potential capacity would allow for some expansion as well as putting less stress on its components.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
The rough math:
- 2 * 275 Watt panels * 0.77 panel+controller deraring * 1/14.5 volts nominal charging = 29.2 Amps on cool/clear day/noonish
- 2 * 275 Watt panels * 1.0 cold panels * 1/14.5 volts = 37.9 Amps winter peak
It is one of those things... You probably get 20% more power in deep winter, but your actual harvest time is pretty short in winter.
And your maximum current is during cold weather--So that is "better" for running near full power...
So 40 amps should do it.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
That’s great. And even better to learn about the cold panel performance. On the on hand we have a lot of cloudy winter days, on the other, I’d need more power in the cold season due to furnace cycling. ... all this to power a small rv, with my cpap as the single biggest draw. Thanks!
Yes.
PWM controllers rated INput amps
MPPT rated by OUTput amps Enjoy
