Never heard of this lithium battery formulation
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
Calling itself "lithium iron phosphate". Again - lithium technology is not my forte. Just a dozen, or so, podcasts.
https://fourvolt.com/products/lifepo4-battery
Also called lithium ferrous phosphate, or LFP. This is the chemistry that most of us on the forum, who have lithium banks, use. This LFP drop in replacement for AGM has a very good price, but series connection is not recommended so would't be a good choice for systems above 12 volts. This type of lithium battery is kind of dummy proof because it protects itself from over and under voltage, high current, and low and high temperature.
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
In general, LFP batteries are "safer" than other Li Ion rechargeable chemistries if over charged/over discharged (they don't explode and catch fire). And they do have a different (lower) charging/discharged voltage per cell.
The "closer" you run the limits, the more "critical" having a BMS (battery management system) is to prevent one cell (or paralleled group of cells) from "hitting the high/low" limit and trashing the cell(s).
As far as I know (not a lot), all the Li Ion rechargeable chemistries have very low self discharge/leakage current and need manual (you) to check/manage cell balance, or get a BMS that alarms (and possibly balance) cells.
Lead Acid batteries (flooded cell), we can "Equalize" a battery bank to "overcharge" the high State of Charge cells, and the "overcharge/leakage" current brings up the lower SoC (weaker cells).
If they can't be wired in series they are presently useless for most of us.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
You can wire the LFP cells in series/parallel as needed. It is the BMS that has to be designed for the overall operating voltage.
Health and welfare on softdown
Many companies producing LFP drop in replacement batteries support series connections, this one, Fourvolt, does not. Here's the FAQ page from their website.
https://fourvolt.com/pages/faq4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Yep! In the store here, about 70 choices.
https://www.solar-electric.com/residential/batteries-battery-storage.html?nav_battery_type=537
You like to speak in code.Dave Angelini said:Health and welfare on softdown
Not really. It does have to be fun for me to play. Maybe an oximeter reading, you are at altitude
How cute - 16 years of Ingsoc psy-ops. Having a challenge finding protocol for membership deletion. Little help please?First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Softdown,
I am very sorry if I went too far.
Sincerely,
softdown said:How cute - 16 years of Ingsoc psy-ops. Having a challenge finding protocol for membership deletion. Little help please?Hey, Softdown:You OK?MarcI always have more questions than answers. That's the nature of life.
