LEDs out
ws9876
Solar Expert Posts: 453 ✭✭✭
My KID controller isnt showing any LEDs lit. But the unit is functioning normally. Anyone know about this issue?
The top one has always ben lit before..
Other than, 1) disconnect solar array (or do work at night), and 2) disconnect and reconnect to the DC battery bus (or flip breaker, if equipped) to reset the controller.
If it does not work, and/or you need further information (depending on replies here), you can also go to the Midnite Forum (started by Midnite, but now run by Midnite users):
http://midniteftp.com/forum/
Always try a reboot when electronics are acting fishy. This issue gets worse every year. Bites tongue clean off...First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
I'd certainly ask at the Midnite forum.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
I fixed it with a firmware update and a reboot.
The first green led from top indicates a full charge in the last seven days.
After 7 days it will go off and orange one will come on.
If you reset the kid, the first green led won't light before a full charge (get to float).
Hope it helps.
Mat
