LEDs out
ws9876
ws9876 Solar Expert Posts: 453 ✭✭✭
My KID controller isnt showing any LEDs lit. But the unit is functioning normally. Anyone know about this issue?
  • ws9876
    The top one has always ben lit before..
    Other than, 1) disconnect solar array (or do work at night), and 2) disconnect and reconnect to the DC battery bus (or flip breaker, if equipped) to reset the controller.
    If it does not work, and/or you need further information (depending on replies here), you can also go to the Midnite Forum (started by Midnite, but now run by Midnite users):
    http://midniteftp.com/forum/
  • softdown
    softdown Solar Expert Posts: 4,062 ✭✭✭✭
    Always try a reboot when electronics are acting fishy. This issue gets worse every year. Bites tongue clean off...
    I'd certainly ask at the Midnite forum.
  • ws9876
    I fixed it with a firmware update and a reboot.
  • mathias
    mathias Registered Users Posts: 31 ✭✭
    The first green led from top indicates a full charge in the last seven days.
    After 7 days it will go off and orange one will come on.
    If you reset the kid, the first green led won't light before a full charge (get to float).
    Hope it helps.
    Mat
