Extr long extension cord for short time...
Photowhit
Solar Expert Posts: 6,023 ✭✭✭✭✭
I can't get my gas chainsaws to run.
I have a downed standing dead the linemen left for me bout 350-400 feet from my inverter.
I'd like to cut it up into small enough sections to haul up to the house and cut down further. I have several 100 foot cords. I think currently 2-10 gauge and 3 - 12 gauge. I have 2 electric chainsaws of 12 and 14 amps and even a limb/pole saw of 9 amps.
What is likely to happen if I try to use them at 400 feet? More amps to make up for the voltage drop of 5-8%? Is it likely to damage the saws? Suggestions?
You may starve the saw for voltage, it will surely slow down, so you can't cut as fast. But faster than by hand !Just don't keep stalling the motor, ease up before stallingPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Well I run , 15amp worm drive framing saws on a 100’ 12 gage cord with grid powerIt will run ok . More then 100’ feet it pops the 20 amp breaker in the house if it’s cold it will pop the breaker in the house .If I keep pushing the saw it will burn up in side .
If I have to work a heavy tool I bring a generator to the work and use a 25’ cord .Just my experience running heavy tools and extension cords JohnOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Same experience with 100' of 12/3 with 14-16 amp tools. I use my little Honda 2000 generator past extension cord distances.I always have more questions than answers. That's the nature of life.
Hello PWHave you tried using starting fluid to get your chainsaw running. What I would suggest is to drain your fuel tank, spray your carburetor clean with carb cleaner, then refill the saw with freshly made gas. When you try to start, spray some SF into the intake. After sitting for more than a year, that what it takes to get my saw running.System 1) 15 Renogy 300w + 4 250W Astronergy panels, Midnight 200 CC, 8 Trojan L16 bat., Schneider XW6848 NA inverter, AC-Delco 6000w gen.System 2) 8 YingLi 250W panels, Midnight 200CC, three 8V Rolls batteries, Schneider Conext 4024 inverter (workshop)
FWIW, I've also found clogged air intake filters tend to compound the problem. Somehow them sitting for a bit seems to "mature" the gunk.Off-grid.
The best thing you can do is run hi test in your saws .When you are done cutting , dump the fuel and run the saw out of gas .My sthil saws are 20 years old and start on the first pull , the see a lot of use .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
I use aviation gasoline (or marine boat fuel) Neither has any ethanol. Aviation gas also is stable for 1 year, all those planes sitting out on the tarmac for months at a time.
Saws should both have been, dumped and run dry, actually found little gas in one. Best friend is logger, I buy Ethanol free gas for him as he live 30 miles farther from the available gas station.
I don't have any starter fluid, and would use WD40 if I had any, they my have sat for 2+years now.
Thanks for the help, if I try Sunday looks like possible day. I'll let you know how it goes.
- 234 Forum & Website
