Connecting panels
mountainman
mountainman Registered Users Posts: 442 ✭✭
With a 400 ah 12 volt Battery and 2 190 panels and 4 100 watt panels.
Which would work better?
With 2 controllers I could
1  use the 2 190 panels on a 30 amp mppt controller and the 4 100s on a separate 30 amp.
2 use the 2 190s  and  3 100s on a 40 or 50 amp cc.
Then use the remaining 100 watt panel on another controller.
2kw array 6 345 q cells  make sky blue 60 cc
 6 230ah GC @36 volts
18 amp accusense charger. 3650 champion
  • mcgivor
    Method 1 keeps like panels working together, which is probably the better of the two.
  • mountainman
    Would using pwm on one array and mppt on the other be a problem as long as both controllers were set with like voltage and absorb times.
  • Estragon
    Should be fine.  I have small pwm arrays as well as larger mppt on both my banks.
  • mountainman
    edited November 2019 #5
    Is it possible that during long summer days with pwm.
     To have 2 arrays on the same controller in different directions.
     2 SE and 2 SW for longer charge absorb times.
    With the advantage of slightly less over night use from batteries.
  • Estragon
    My understanding is it isn't a good idea to have different array orientations on a single mppt controller, as it can make finding a max power point a problem.
  • mcgivor
    With PWM different orientation on a single controller would not be an issue, which was the question.
  • Estragon
    Sorry, missed the pwm reference.  Post 3 referenced both mppt and pwm.
  • mountainman
    Thanks @Estragon and  @mcgivor.     sorry for the confusion.
    Think I may have worded it wrong.
     On pwm Would it be better to use 3 aimed se.
    And 1 sw since in the morning bulk needs more power than absorb in the afternoon?
  • Estragon
    Yes, AFAIK with pwm the differently aimed panels will just put out more or less current than others on the controller.  Pwm doesn't track max power point, so the mismatch shouldn't matter much.
    I assume the panels are 4 in parallel.  I wouldn't split a series string across different orientations.
  • mountainman
    Yes all 4 are in parallel.
