Off grid cabin upgrade help
spanel
Solar Expert Posts: 36 ✭✭
Current setup
2 135 12v panels
2 6v 220ah batteries
We have had this setup on our small cabin(hunting/rec we dont live here) for 8 years and its time for an upgrade. This has served us well as we have a backup inverter genny (2800watt). It lasts about a day or so cloudy and we have to run the genny after that.
Here is what I am thinking to upgrade.
6 x 325watt 24v panels
8 x 6v 220ah batteries.
Magnum RD1824 invertor/charger
I know it will be better than what we have.
This will be 4x more runtime?
What will be a good charge controller?
Thoughts?
Chris
2 135 12v panels
Thoughts?
Chris
Any particular reason for 24v nominal bank voltage? As you're replacing the inverter anyway, you might want to consider 48v, which would give you the same storage in a single string, and require 1/2 the controller amp capacity.Off-grid.
Where will the solar Charge Controller be located ? Would noise from a fan be objectionable (sun hours only) ?I have 2 I like and usefanless Morningstar MPPT 60 (with integral web server)fans Classic 150 ( also has ethernet port for use with Local App )And I agree with Estragon's 48V suggestion
Yea - plenty strong paneling to warrant the 48 volt upgrade - which has no downside that I am aware of. Suddenly your wiring acquires twice the efficiency and capacity.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Main downside IMHO used to be a lack of decent small (eg 300w) PSW 48v inverters, though there are a few now.
Also, there are lots of common loads that can use 12vdc, fewer use 24v, and even fewer use 48v.Off-grid.
Unless you're on a tight budget you can set up a separate 12 volt system. Usually these don't need to be large, I have a single 120 watt 12 volt panel PWM controller and a couple 6 volt deep cycle batteries powering a VHF marine base radio, a Sure-flo water pump and 12 volt stereo. This puts very little stress on the batteries, which probably never get below 90% soc.
