Off grid cabin upgrade help
spanel
spanel Solar Expert Posts: 36 ✭✭
Current setup
2 135 12v panels
2 6v 220ah batteries
We have had this setup on our small cabin(hunting/rec we dont live here) for 8 years and its time for an upgrade.  This has served us well as we have a backup inverter genny (2800watt).  It lasts about a day or so cloudy and we have to run the genny after that.
Here is what I am thinking to upgrade.
6 x 325watt 24v panels
8 x 6v 220ah batteries.
Magnum RD1824 invertor/charger
I know it will be better than what we have.
This will be 4x more runtime?
What will be a good charge controller?
Thoughts?
Chris
  • Estragon
    Any particular reason for 24v nominal bank voltage?  As you're replacing the inverter anyway, you might want to consider 48v, which would give you the same storage in a single string, and require 1/2 the controller amp capacity.
    Off-grid.
    edited November 2019 #3
    Where will the solar Charge Controller be located ?  Would noise from a fan be objectionable (sun hours only) ?
    I have 2 I like and use
    fanless  Morningstar MPPT 60 (with integral web server)
    fans   Classic 150 ( also has ethernet port for use with Local App )
    And I agree with Estragon's 48V suggestion
  • softdown
    softdown Solar Expert Posts: 4,081 ✭✭✭✭
    Yea - plenty strong paneling to warrant the 48 volt upgrade - which has no downside that I am aware of. Suddenly your wiring acquires twice the efficiency and capacity.
  • Estragon
    Main downside IMHO used to be a lack of decent small (eg 300w) PSW 48v inverters, though there are a few now.
    Also, there are lots of common loads that can use 12vdc, fewer use 24v, and even fewer use 48v.
    Off-grid.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,199 ✭✭✭✭✭
    Unless you're on a tight budget you can set up a separate 12 volt system. Usually these don't need to be large, I have a single 120 watt 12 volt panel PWM controller and a couple 6 volt deep cycle batteries powering a VHF marine base radio, a Sure-flo water pump and 12 volt stereo. This puts very little stress on the batteries, which probably never get below 90% soc.
