230v appliance (Incinerating toilet) with sw4048 120/240?
mike95490 said:Are there any trees around ? ( for the men ) boiling water away is a hugely inefficient way to use solar powerYes, plainty of trees around, I got a DIY urinal for ladies.How many batteries do you guys think?I currently got two 12v AGM 203 watts each.
With 200ah@12v batteries, you could do 2 strings of 4 batteries (eight total) for 400ah@48v, ~19kwh.
That gives ~3days autonomy at 3kwh/day to 50% state of charge. 4kw of pv should be enough to recharge from 50% SOC in most climates. Whether 3 days autonomy is enough to avoid going below 50% SOC with no alternate means of charging, I don't know.
If the climate is such that there are longer runs of gloomy weather, the bank could be bigger and/or a generator added. If using a larger bank, I'd use lower voltage / higher amp-hour batteries to keep the number of strings to one or two.Off-grid.
So eight batteries could do it.I plan to get lithium later.
kakarot said:So eight batteries could do it.I plan to get lithium later.I'd say look into the loveable loo :https://www.treehugger.com/lawn-garden/a-composting-toilet-for-195-the-loveable-loo-video.html
https://www.milkwood.net/2012/08/17/building-a-jenkins-style-lovable-loo/There are free plans for many loos built around a 5 gallon bucket, using sawdust, peat moss or other materials.After years of alternatives and trying all sorts of ideas, the bucket, a seat platform, and a scoop of dry carbonaceous is the real deal,until you get a flushing septic system in place.
From experience I might add, If you can acquire a 7 gallon bucket you might prefer it to the shorter 5 gallon variety.mike95490 said:kakarot said:So eight batteries could do it.After years of alternatives and trying all sorts of ideas, the bucket, a seat platform, and a scoop of dry carbonaceous is the real deal,until you get a flushing septic system in place.
Now I got 8 x 110Ah AGM batteries.I will make two 48v banks and then connect them in parallel48v 110 Ah x 2 = 48v 220AhI guest that would give me 10kwhMore than enough to run this toilet by 3 people every day.
Update:I've got 12 Gel batteries12v each110Amp eachAll setup to make 3 banks of 48v = 330Amph @ 48v330Amp x 48v =15840kwh15840kwh / 2 = 7920 kwh7920kwh at 50% of battery useI've got the cheap chinese inverter/charger 5kw, 80amp, 48vtested the toilet which is at 230v, all is working it burns a banana to ashes so i guess all good.
