Where to buy 4 ought cables.
solorone
Solar Expert Posts: 257 ✭✭✭
I have prices of 3 $ a foot for 4 ought cable without lugs, and up to 8$ a foot for 4 ought with lugs. Anyone have suggestions for anything in between? I do not want to make my own lugs this time.
Thanks and cheers.
Thanks and cheers.
Have you tried local welding supply and battery distributors and see if they have/make up cable sets?
I guess you are in Georgia, so if anyone has a local to Solrone source--Please let him know.
Your pricing does not sound bad:
https://www.solar-electric.com/residential/wiring-cables/battery-inverter-cables.html
You should check the insulation type--Some types are better than others. Our host generally uses MTW (machine tool wire) for this cabling.
Most of what I have used was THNN I think, acquired 1000 + feet back in 84. I can buy welding cable locally for 5$, I just wanted the lugs crimped. I have been crimping my own for years with no issue. This is for an old customer's rebuild.
I measured, cut and took my cables to a local Interstate Battery store. They provided the lugs and crimped them on for a very reasonable price.
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Thanks for that tip. I will call around and check.
