Where to buy 4 ought cables.
solorone
solorone Solar Expert Posts: 257 ✭✭✭
I have prices of 3 $  a foot for  4 ought cable without lugs,  and  up to 8$ a foot for 4 ought with lugs.  Anyone have  suggestions for anything in between?  I do not want to make my own lugs this time.
Thanks and cheers.
    BB. Super Moderators, Administrators Posts: 33,734 admin
    Have you tried local welding supply and battery distributors and see if they have/make up cable sets?
    I guess you are in Georgia, so if anyone has a local to Solrone source--Please let him know.
    Your pricing does not sound bad:
    https://www.solar-electric.com/residential/wiring-cables/battery-inverter-cables.html
    You should check the insulation type--Some types are better than others. Our host generally uses MTW (machine tool wire) for this cabling.
  • solorone
    edited August 2019 #3
    Most of what I have used was THNN I think, acquired 1000 + feet back in 84. I can buy welding cable locally for 5$, I just wanted the lugs crimped. I have been crimping my own for years with no issue. This is for an old customer's rebuild.
  • Raj174
    I measured, cut and took my cables to a local Interstate Battery store. They provided the lugs and crimped them on for a very reasonable price.
    Rick
  • solorone
    Thanks for that tip.  I will call around and check. :)
