16 lithium cell 200AH per
                    DarkstormNH
                    Registered Users Posts: 48 ✭✭
                    Hello All I just took the plunge and purchase 16 of these prismatic cell  200AH Each.
I would to get some feedback on configuring them for 24 volts.
I can make 2 8s bank and parallel them, or sell my 24 volts inverter (magnum) and purchase a 48 volts
so That I can create a 16s bank.
lastly has anyone used a similar approach using the pt100 to charge a lithium bank?
Please advise
Please advise
            When using lithium cells to create a 24V nominal battery the best method would be to first parrallel the cells to create cell blocks, then series the blocks. With 16 cells the topography would be 2P 8S, the advantage of this is that only one battery management system (BMS ) would be required, unlike two separate 8S batteries which would require two BMS's.
 Obviously a 16S battery would require a single BMS and has other advantages such as smaller conductor and over current protection,
 This link explains in detail how to build a Lifepo4 battery with prysmatic cells.
 http://nordkyndesign.com/assembling-a-lithium-iron-phosphate-marine-house-bank/
 What is a pt100 and which cells do you actually have?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
            Thank you for the feedback I will follow the cell block approach, the PT100 is the charge controller from magnum
 the cell that I have are CALB prismatic 200AH
            Take the time to study as much as possible before getting started, the first step is to ballance all the cells before assembly of the final topography, you will need a single cell lifepo4 charger, if possible get one with at least 10A as 16 cells in parallel ballancing will take an extremely long time, assuming 50% charged on delivery that's 1600Ah, at 10A the charging time will be 160 hours or more. Take this one step at a time to avoid confusion stating with ballancing.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
            @DarkstormNH
 Good cell choice. Did you get enough buss bars to parallel 16 cells? If not informed when purchasing, this particular CALB has two different buss bars, standard: side by side, and non-standard: end to end. Paralleling 16 cells for top balance will require 30 standard bars. Graphic below. Did you get these from Electric Car parts Company?
 Rick
            Raj174 said:@DarkstormNH
 Rick
 I received 18 bus bar I'm going to buy some flat copper and make my own, I bought the cell from china
- 232 Forum & Website
