Battery charging
oadkins
oadkins Registered Users Posts: 19 ✭✭
Charge regulator getting hot and panel wires burn end off the is 100 watt meter progressing 29watts what to check first 8 gage wire old 100watt panels
    How are they wired, and how many, what charge regulator (Charge controller?)
    I worry you have  series wired into a PWM charge controller, or have too much current for the model charge controller... So as much information as possible please.
  • oadkins
    System has been working for four years just had to put new charge controller on because of. burnt wires .I use m we charge controler
    Do you have loose connections, water/humidty caused corrosion? Using any Aluminum wiring?
    I have seen fine copper wire that seems to corrode much worse that solid or course stranded copper wire (especially over time and higher temperatures)...
