Battery charging
oadkins
Registered Users Posts: 19 ✭✭
Charge regulator getting hot and panel wires burn end off the is 100 watt meter progressing 29watts what to check first 8 gage wire old 100watt panels
How are they wired, and how many, what charge regulator (Charge controller?)
I worry you have series wired into a PWM charge controller, or have too much current for the model charge controller... So as much information as possible please.
System has been working for four years just had to put new charge controller on because of. burnt wires .I use m we charge controler
Do you have loose connections, water/humidty caused corrosion? Using any Aluminum wiring?
I have seen fine copper wire that seems to corrode much worse that solid or course stranded copper wire (especially over time and higher temperatures)...
